REAL directions to install a GSR Cluster in your EF!!!!
Old 03-30-2003, 08:29 AM
dingusjt's Avatar
Default REAL directions to install a GSR Cluster in your EF!!!!
well i'm not sure if anyone actually tried the instructions found at http://www.angelfire.com/dc/oregonimport/gsr1.html
but it my opinion they are complete crap, but thats just from my experience so i'm not bashing on anyone's knowledge or information but here is what i found out, and it works.......
every wire will match up by color except...
(GSR)blue/red to (CRX)red/blue
(GSR)green to (CRX)green/black
and to hook up electronic VSS...
blue/white to orange
black/yellow to yellow
black is the ground.
This is for 94+ GSR clusters, i'm not sure about other years.the only thing i couldn't get to work properly was my fuel gauge.
so don't be afraid this swap is actually easy as hell if you have the connector plugs, it took me about 4 hours of frustration to figure out how simple it really was.
Old 03-31-2003, 08:58 AM
CrxSi10's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (dingusjt)
What about the signal from the ecu and did you get the seat belt to work? As for the fuel gauge follow this instruction from Blow'N'Crx. That dude you got the instructions from switched the seat belt and fuel gauge wires around, not to mentioned had other stuff wrong or missing also.
You get the vss out of y1 trannys, at least thats were i got mine.
here is all the wiring i used to do mine...
1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Green/Red-Door Light
8)Red-Dash-Dash Lights
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11)red/Blue-High beam
12)Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Feul Gauge
4)Not Used
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
2)Geen/Orange-Check engine
3)Yellow/Orange-Oil Light
4)Not Used
5)White/blue-Volts
6)not used
7)Yellow/green-Water Temp.
8)black-ground
9)Red/Blue- cruise(not used unless you have it)
10)Yellow-12vPower
11)Not Used
12)Not Used
13)Not Used
16 Pin connecter
1)Green/red- E brake
2)red/Green-High Beam
3)Green/Yellow-Right Turn signal
4)Green/Blue Left turn signal
5)not Used
6)black/yellow-12vPower
7)Red/Black-Power
8)Red-12vpower
9)blue/Red-ABS(not used unless you have it)
10)green-Trunk Light
11)Orange-VSS
12)not used
13)Blue/White-Low Feul(not used unless you have it)
14)Yellow/white-Feul Gauge
15)Green/Red-door
16)red/blue-seat belt
hope this helps worked perfect for me just match the wires up.
[Modified by CrxSi10, 5:59 PM 3/31/2003]
[Modified by CrxSi10, 6:00 PM 3/31/2003]
Old 04-06-2003, 05:34 PM
ghettocrxsi's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (CrxSi10)
it depends on the year of the car but.. it is either a red/blue wire to a yellow/white wire.. for fuel or white/yellow to white/yellow...
again it depends on the year 88-89 or 90-91.. and dont go bashing my website.. its just a guide not a perfect match..
it even says use this at your own risk.. its a guide.. And all the wires worked perfect on my car that is a 91 crx si.
EDIT! Not to mention you are using the wrong damn address.. its http://www.angelfire.com/dc/oregonimport/gsr.html there is no 1... check that link I just posted.. Now stop bashing
[Modified by ghettocrxsi, 6:35 PM 4/6/2003]
Old 04-06-2003, 06:13 PM
dingusjt's Avatar
like i said...i didn't mean to offend or disrespect i guess if it wasn't for your instructions or site i wouldn't of even tried this mod in the first place so i do appreciate it...just your directions didn't work out for me and led to about 3 hours of frustration
[Modified by dingusjt, 3:15 AM 4/7/2003]
Old 04-06-2003, 06:33 PM
Ya sorry for like freaking out.. Also you are using the old page not the updated one with vss wiring and the correct pluging http://www.angelfire.com/dc/oregonimport/gsr.html thats the newer version
Old 04-06-2003, 06:41 PM
I took way too long
slowman's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (ghettocrxsi)
This sounds cool. Anyone have pics of it installed
Old 04-06-2003, 06:44 PM
dingusjt's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (slowmanEF)
hey email me for some pictures i can never get the damn things posted...but keep in mind that apparently they clusters fit better in CRX and HB, of course id on't know why this would be the case being that CRX and HB gauge clusters are the same as LX EX, oh well
Old 04-06-2003, 06:45 PM
Yes here are some of mine when I first did the swap and made the tech article back in september
Old 04-06-2003, 06:54 PM
FourthGenHatch's Avatar
Does that cluster just bolt right up? It looks like it fits in perfect.
Old 04-06-2003, 07:41 PM
smokey2.0's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (FourthGenHatch)
any pictures of this cluster, installed on a 88-89 crx?
Old 04-06-2003, 08:37 PM
Don't call it a comeback
Stunna BEN's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (smokey2.0)
Does anyone have the diagram for the 90-93 teg cluster in a 88-91? If so it would be greatly appreciated along with pics!!!
Very nice work guys
Old 04-06-2003, 11:11 PM
PhatHardy's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (Stunna BEN)
ooh finaly got ya ghettocrxsi, i'm gonna semi-bash on you, your site is all wrong, dude i had that thing and it didn't work for ****, (hopefully you will fix it with the one that the dude posted on this thread, i found that one and worked like a charm.) so please stop sending people to that site, because it's not correct, and just to add to this thread
the 94+ integra clusters do not just bolt right up, you must shave off both(sometimes just one, if you are clever, i'm not :hammer and then take out all the things that hold the old gauge cluster in(little metal brackets) and then you place it in there and there is a screw hole in the gsr gauge cluster and you put a screw threw your little viewing area (the place that the cluster sits in) if you look closely in hte pictures posted above you can see the screw.
oh and please don't take to much offense ghettocrxsi, it's all good
Old 04-07-2003, 03:49 AM
I took way too long
slowman's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (PhatHardy)
I want to do this Looks real nice.
Old 04-07-2003, 10:12 AM
uneek4dr's Avatar
i have done the 90-93 cluster into a 89 civic. email me if you want all the info. i did a complete write up ill post the link
Old 04-07-2003, 10:19 AM
uneek4dr's Avatar
http://www.4thgenerationcivic.com/ho...ket-Custom.htm
scroll all the way down.
that is my how to on the 90-93 cluster into a 88-89 civic. if you need any help just ask.
Old 04-07-2003, 10:33 AM
crexer's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (uneek4dr)
So does the speedometer cable just hook right up?
Old 04-07-2003, 05:11 PM
uneek4dr's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (crexer)
yupjust pop it in and away you go
Old 04-07-2003, 06:44 PM
smokey2.0's Avatar
cool, i'll check out the website!
Old 04-07-2003, 06:52 PM
Stunna BEN's Avatar
Can we get a pic of the finished product??
Old 04-07-2003, 09:50 PM
Im not offended at all.. it works for me and everyone of my friends and people who email me.. you have to make sure and look at the page http://www.angelfire.com/dc/oregonimport/gsr.html not gsr1/html...
any ways if u read the directions on my site it tells you that u need to remove your old guage cluster mounts.
The metal tabs and also have to shave the ears off and put the screw in. Just like in the pics..
I will be simplifiing the wiring alot so people can plug and play basically..
But I have school and work and my turbo motor I am building .. so that leaves little time for the site..
Old 04-08-2003, 05:07 AM
blacksheep's Avatar
That **** looks hella good! Clean.. real clean!
Old 04-08-2003, 06:50 AM
In The Garage
Shawn C's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (blacksheep)
so.............. all the plugs and wiring is the same for 94-01 GSRs? it didnt change in 96 for the OBD II cars? might be a dumb question, but i want to know before i try this. thanks
Old 04-08-2003, 08:08 AM
ViperRedCRX's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (22lbGS-R)
any draw backs to doing this? does everything work correctly? i'm really considering doing this, but i want to make sure it will work 100% first.
my car is already obd1, don't think that makes a difference. i know i have to run an electronic speed sensor, and that's not a problem. i have a few laying around. does the electric vss fit into the cable tranny correctly?
Old 04-08-2003, 07:25 PM
smokey2.0's Avatar
Default Re: REAL directions to install a GSR Cluster in your EF!!!! (ViperRedCRX)
the VSS will fit the cable tranny case, with no problems!
Old 04-10-2003, 05:37 PM
Vss and everything fit..
The 94-99 plugs are the same but the 00-01 plugs have a different gound I believe I am unsure.. I will try my buddies 01 itr cluster and see if it works on my car. Ill let u guys know
Quick Reply: REAL directions to install a GSR Cluster in your EF!!!!
