How do you know when the o2 sensor has gone bad???
Old 02-03-2003, 04:36 AM
VSM EXtasy's Avatar
Default How do you know when the o2 sensor has gone bad???
I have a 99 Civic with a p28 ecu/hondata. One day when driving all the leds strarted to light up on the auto meter a/f gauge and the car started to sputter and misfire.
I'm not getting any CE lights at all. I read some posts in the archieves which makes me believe its the o2 sensor that has gone bad. But why not CE light???
Old 02-03-2003, 05:50 AM
White Lightnin's Avatar
Default Re: How do you know when the o2 sensor has gone bad??? (VSM EXtasy)
I had my o2 sensor code go off once over the summer. Fiddled with it and it went away. When I went to smog I failed big time. Im running really rich and have killed my catylitic convertor. One explanation is the o2 sensor so Im swapping it out for a new one.
Old 02-03-2003, 06:17 AM
BudaKai's Avatar
You won't get a cel usually. The ECU is set-up to correct for the o2 if it doesn't get a reading. Hence the reason it usually runs really rich when the o2 goes out.
Old 02-03-2003, 08:20 AM
Speed PHreak's Avatar
Default Re: How do you know when the o2 sensor has gone bad??? (tzsir)
The ECU goes into "limp mode" to protect the engine from damage when it sences that the O2 isn't functioning correctly. It runs the engine extra rich. My O2 is shot so bad that my car won't idle. Nice huh?
Old 02-03-2003, 08:38 AM
GOLDBERG's Avatar
Default Re: How do you know when the o2 sensor has gone bad??? (Speed PHreak)
the shop that did my friendsmotor swap(b16 into 92 hatch) cut both his o2 sensors..any idea why he wouldve done something like that???my friends car backfires alot too
Old 02-03-2003, 08:47 AM
Should have realized it before when my car was idiling horribly. Also when i remved my header and found a huge soot deposit on all my exhaust ports. All shold be fixed soon though.
Old 02-03-2003, 08:58 AM
BudaKai's Avatar
I've never gotten a cel for o2. Must be my luck I guess. I was driving around for two weeks wondering what was going on. I noticed the wastegate was all cruded up so I investigated it to find out why. Found the lead to my o2 sensor had wiggled off. I was worried for a while that it may be something worse.
NightHawkBlack-R
02-16-2009 10:28 AM
UNKNOWN_MEMBER
02-23-2005 11:05 PM
adrenajunky
10-13-2004 06:18 PM
boost fed ls
08-31-2004 07:45 PM
Shakes
04-28-2004 08:45 PM
Quick Reply: How do you know when the o2 sensor has gone bad???
