high pitched whistling noise
Old 02-01-2003, 01:12 PM
da94ludesi's Avatar
Default high pitched whistling noise
ever since i have installed my header, there has been this high pitched whistling noise, but it only happens under semi and hard acceleration. on idle its quiet and on the highway there is no high pitched noise. It kind of sounds like an exhaust leak but, i used new gaskets and everything and tightened all the bolts solid. what do you guys think?
Old 02-01-2003, 01:43 PM
Lord Helmet's Avatar
Default Re: high pitched whistling noise (da94ludesi)
need more info on your car and what have you done to it.
Old 02-01-2003, 03:22 PM
leadfoot78's Avatar
Default Re: high pitched whistling noise (sleeperciv)
my skunk2 intake with just a big filter on it makes a whistling noise kinda like a supercharger, I kinda like it.
Old 02-01-2003, 03:29 PM
joe_bocc's Avatar
Default Re: high pitched whistling noise (leadfoot78)
After installing your new header, did you check for leaks?
Also, did you make sure the gaskets are in the perfect place? Sometimes, the gasket can shift when you are tightning the bolt and it can restrict the flow by sticking out from the side which might be able to cause a whistling sound.
Old 02-01-2003, 03:32 PM
da94ludesi's Avatar
Default Re: high pitched whistling noise (joe_bocc)
i have a 94 honda prelude si, with cai, exhaust, header, venom 400, thats bout it. IT may be a gasket thats not on completly straight, but i may be losing my hearing cuz i swear it sounds like its coming from the back of my car (near the muffler) I will look at the gaskets tommorow i guess
Old 02-01-2003, 03:57 PM
Desslok's Avatar
For some reason when I installed my header, my heat shield rattles like a **** under load around 3500-4000 RPMs. Could it be yuor heat shield?
Old 02-01-2003, 05:34 PM
da94ludesi's Avatar
Default Re: high pitched whistling noise (Unexplained 98 percent)
no not the heat sheild, and its not a rattle either is definatly sounds like AIR flowing....but i read a little in my chiltons, and i think it may be one of two things, it said that if you leave ur pipe unsupported that it can crack....maybe my pipe has cracked near my muffler....or....I dont think there was a gasket between my collector and catalytic converter, if there was one on there its still there cuz i sure as hell didnt take it off. I didnt replace that either. I will look tommorow.
Old 02-01-2003, 06:09 PM
In The Garage
Shawn C's Avatar
the best way to find an exhaust leak-------- pull off the hose on the intake manifold that goes to the brake booster. put your thumb over it while somebody starts your car. use a bottle of DEXTRON III w/ MERCON (regular ATF). pour it in the vaccuum tube on the IM as you slowly move your thumb. it will suck it into your engine, and smoke profusely. dont worry about it hurting the engine, all it will do is clean off some carbon buildup. the only thing it can do is foul the plugs from all the smoke, but new plugs are like 8 bucks. put the vaccuum hose back on and give it some gas. smoke will come out of all exhaust leaks. you have to do this fast, cause it will stop smoking after all the tranny fluid is sucked through. after you find the leak, youll probably have to run it up and down the street for a minute to get all the ATF out. i promise it wont hurt anything, so dont worry about that. it actually helps. but you will definitely find the leak.
GhettoNinja06
Honda S2000
28
06-08-2012 10:45 AM
supracrx
12-04-2008 07:28 PM
M15
09-15-2005 05:06 AM
Threads
20
08-31-2004 04:30 PM
96AccordExCpe
06-25-2003 11:33 AM
Quick Reply: high pitched whistling noise
