Is it possible to pass emission without catalytic converter?
Old 01-25-2003, 11:32 AM
Hard2Find's Avatar
Default Is it possible to pass emission without catalytic converter?
anyone here pass their emission without catalytic converter? (just testpipe)
Old 01-25-2003, 11:33 AM
BeerBaron105's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (Hard2Find)
only if ur car predates emissions standards
Old 01-25-2003, 11:35 AM
VTECTIME's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (BeerBaron105)
or you bypass the exhaust to come out somwhere else like the front of the car. AHAHAHA use a home depot hose
Old 01-25-2003, 12:22 PM
Phaze2 Mike's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (VTECTIME)
If somehow your car was like a super ultra low emissions vehicle i suppose it could happen. The prototype Neon SRT-4 doesnt have mufflers, which isnt the same, but frankly, get a cat, the change-out time is negligable.
Old 01-25-2003, 12:30 PM
deepnite's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (Nextekhatch)
nope
Old 01-25-2003, 01:49 PM
ejprimo's Avatar
most likely not.
Old 01-25-2003, 02:10 PM
tararan's Avatar
no way.....
Old 01-25-2003, 02:24 PM
94hondaLS's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (tararan)
Nope even if it passes emissions part it wont pass visual
Old 01-25-2003, 03:34 PM
hadboosttroy's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (94hondaLS)
well in oregon if your car is 96 or newer (OBD2) as long as your car doesnt throw codes it doesnt matter. i asked the emissions guy specifically and he said they dont check for it on your car, it just cant throw any check codes.
Old 01-25-2003, 04:03 PM
scdarksol's Avatar
Default Re: Is it possible to pass emission without catalytic converter? (hadboosttroy)
I'm an emissions inspector. And it's actually a yes and no. First of all everybody would expect a cat on the car, and you should (for the good of the future). Here in Pa it would fail for visual, but knowing many inspectors, they won't crawl underneath the car and look, unless it's suspicious (like hooked up cars), basically I think it will pass if it's a ULEV vehicle. But a regular civic without cat I know for sure won't pass. And as for OBDII cars. If you take out the cat, check engine light will come on. And it won't pass. Please don't take out your car, cause it's really not worth it. You could get a ticket for $2000, and it really don't give you that much more horse power, you actually might lose power, since you don't have any back pressure. If you want to have some more performance get a high flow cat from summit for $100 keeps your out of trouble!
La Zona Imagery
05-23-2016 11:05 PM
Nicks95GSR
05-21-2008 07:37 AM
LShatchie
22
12-22-2004 03:28 PM
cappa
12-01-2004 02:33 AM
integgidy
12-13-2003 03:16 PM
Quick Reply: Is it possible to pass emission without catalytic converter?
