Car Sputtering at low speeds
Old 08-31-2014, 10:42 PM
breakit's Avatar
Default Car Sputtering at low speeds
So I gotta 93 accord 10th anniversary edition, 218K on it
The car runs great on the highway but after about 15 miles the CEL light kicks on (code 43 fuel supply system) and I get a real bad gas smell inside.
the problem is most noticeable after shutting it off after driving it long enough to warm it up, then STARTING IT BACK UP and going speeds under 40mph.
I give it just a little gas and it will start to sputter sounding like its going to die but the RPMs stay the same and it doesn't seem like theres a loss of power. Again im smelling gas inside. But then I put more foot into giving it more gas and the thing starts running like a champ again. I just don't get it.
I don't think it can be spark as I got a brand new set of plugs, wires, ignition coil, ICU. and new manifold gasket with brand new spark plug tube o rings, so theres no oil on the plugs. Brand new WIX fuel filter as well.
there are no vaccum leaks. all the fuel lines look good. If it was a fuel pump I would be getting some stalling on the highway and a big power loss right? IM stumped.
Old 09-01-2014, 03:38 AM
holmesnmanny's Avatar
If you smell gas then you have a leak. Find leak. Fix leak.
Old 09-01-2014, 10:01 AM
breakit's Avatar
Default Re: Car Sputtering at low speeds
Good thought holmesnmanny but im pretty sure if I had a leak I would smell it all the time instead of just when I get a few miles down the road. And like I said I Looked at the few lines and I went all over under the car, no fuel on the ground or on any of the lines/tank/fuel filter/fuel rail
Old 09-01-2014, 03:42 PM
So you really think it's normal to be smelling raw fuel ? Considering you got a code 43 for fuel supply issue I would think it would be common sense to think there is a fuel supply issue somewhere.
Hook up a fuel pressure tester. You can get one from Harbor Freight. Turn the ignition on. Then immediately turn it off. The gauge should hold steady. If it immediately starts to bleed down you know you got a leak.
It is possible your oxygen sensor is so bad it's dumping excess fuel in.
It would actually be best to hook up the gauge before you drive it and make it do its thing. When it throws the code, safely pull over. Turn the car off and immediately check the gauge. The pressure should be atleast 30+ and again it should hold steady.
Old 09-04-2014, 02:26 PM
breakit's Avatar
so I tested my oxygen sensor, I got .03 ohms out of the two black wires. But I also had no 12v feed on the other half of the connector so im guessing that's what the problem is.
So I guess ill have to replace the o2 sensor as well as the wireing problem.
Old 09-04-2014, 03:17 PM
Were you testing voltage with the ignition on ?
Old 09-04-2014, 05:45 PM
breakit's Avatar
yes sir with the key on, without the engine running. Im really confused on what to check from here and what to do.
Also kinda worried that it's no the actual problem considering theres a code for the o2 sensor by itself I believe. and im getting a fuel supply code.
I just don't have to money for a fuel pressure guage right now. But I will be testing that sometime soon when i do get the cash.
Old 09-04-2014, 06:33 PM
94 accord typeR's Avatar
google search my friend
https://honda-tech.com/forums/honda-accord-1990-2002-2/help-1991-accord-ex-check-engine-code-43-%22fuel-supply-system%22-1590857/
Old 09-05-2014, 01:02 PM
breakit's Avatar
SO I found this http://home.icequake.net/~nemesis/bl...comment-page-1
Been googling my *** off lately trying to figure this stuff out and I still hardly understand all the electrical gibberish.
I was wondering if it would hurt anything just to unplug the o2 sensor from the ECM and drive it around to verify if that's the problem. Because that ECM wire plug has been on for years and years and I cant for the life of me get the damn thing off I tried spraying it with WD-40 and using pliers and all that. I am so pissed off right now It's making my stomach ulcer come back.
Efluis
06-27-2019 09:42 AM
crook803
11-18-2017 04:36 PM
JDMb20Ferio
09-09-2008 08:54 PM
flyguy0086
01-23-2007 10:11 PM
redciviclx14
06-28-2003 08:01 PM
Quick Reply: Car Sputtering at low speeds
