96 acura integra wont start please help
I have a 96 integra was running fine. I normally bypass my ignition switch and hot wire it as I lost my key. My kid jumped in the driver side hit my main power wire for ignition to bare metal it sparked and the car would not start no fans no radio no fuel pump sound nothing but my exterior lights and chimes work. My ignition fuse blew so I replaced it but still yet nothing. My battery is new and I had it re tested all still good. I have power to my starter solenoid and my main relay and my main relay looked ok still. Need help please I'm stumped....
Re: 96 acura integra wont start please help
Check ALL your fuses! so the $30 keys from AZ aren't an opinion ? that's seriously not safe what you're doing.
did the ign fuse blow a 2nd time?
Ignition fuse didn't blow second time still good. All other fuses are good checked multiple times. Car wont jumpstart, I can bumpstart it but it won't rev when u push the gas and when u engage the clutch again it dies. I'm wondering about the ecu as nothing comes on when you try to start...
kintaro
08-22-2008 03:31 PM
curiousgpnoy
01-03-2004 11:15 AM
