Can a f23a fit in a 96 s prelude
Re: Can a f23a fit in a 96 s prelude
Someone can correct me if I'm wrong but I believe you need the rear, transmission, and front motor mounts from the preludes original engine. Power steering won't work without modification. Easiest way for me when I did it was to leave the F series engine harness with the engine it should just plug into the plugs on the chassis. At least 91 accord to 93 lude worked that way. Dizzy can be a pain depending on if your going from external to internal or internal to external. Hope this helps. I've done 2 F swaps into a 93 and a 95 lude. F22A1 and F22B2 I imagine its the same if not similar in a 96 with an F23.
scrubdakiller80
07-29-2016 03:37 AM
