what textured paint/liner to use on tow-dolly?
Old 07-22-2014, 01:30 PM
Charlie Moua's Avatar
Default what textured paint/liner to use on tow-dolly?
My dolly use to be white, but the paint has pretty gone and there's some surface rust.
I'd like to paint it something durable & easy to apply.
I've seen some jeeps, roll cages which have been painted with a tough liner coating.
What tough/textured wrinkle paint coating do you guys have experiance with that you would reccomend to use on a dolly?
Old 07-22-2014, 05:37 PM
94 accord typeR's Avatar
Default Re: what textured paint/liner to use on tow-dolly?
any general under carrage paint. u want to fix the rust first or use rust eliminating primer.
or just buy a new tow dolly and white spray paint and touch it up whenever it chips. u can even clear coat it to protect the finish
Old 07-23-2014, 04:07 AM
scottdh20's Avatar
truck bedliner....but the surface needs to be really clean... use a flapper wheel and buzz down any surface rust, remove all loose or chipping paint(you may want to sand blast it) then knock it all down wth some 200grit and then apply the bed liner
Old 07-23-2014, 05:13 AM
thanks for the advice guys.
I'll see if some local shops have portable media blaster... that may be the easiest vs. spending hours sanding down the entire dolly.
dem0nk1d
Paint and Body
04-15-2011 03:21 PM
67marobird
Honda S2000
07-16-2007 05:46 PM
johnzm
02-24-2003 08:37 AM
zseeanz
11
12-13-2002 08:59 PM
B16A2
05-20-2002 05:57 AM
Quick Reply: what textured paint/liner to use on tow-dolly?
