anyone know what this part is please !?!?!?!
Old 07-19-2014, 08:05 AM
hydell3's Avatar
Default anyone know what this part is please !?!?!?!
this was in my oil pan, i have no clue what it is..Name:  IMAG0353.jpg
Old 07-19-2014, 08:08 AM
1998GsRIntegra's Avatar
Default Re: anyone know what this part is please !?!?!?!
Thrust Washer. Pretty high on the importance list as far as internal parts go. Crank is going to walk with out it.
Old 07-19-2014, 08:16 AM
longest project ever
lostforawhile's Avatar
right now it's walking, but inevitably it will take a ****
Old 07-19-2014, 08:42 AM
ROFL ^^^^
Old 07-19-2014, 09:44 AM
tollickj's Avatar
Thrust washer, it goes against the wall of journal number 4 if you were to look at your main caps/ girdle. If I was you I'd advise getting a Haynes manual, the best way to learn about the motor/car.
Old 07-19-2014, 11:33 AM
B_Swapped93's Avatar
not a good thing to find in the oil pan! stop driving it and tear it apart or grab a new block.
Old 07-19-2014, 11:35 AM
hydell3's Avatar
the motor is out i bought it with a knock supposedly and this must have fell out when i was hand rotating it
Old 07-19-2014, 11:44 AM
well there's what you were hearing lol (or at least a contributing factor). you need to rip it apart
Old 07-19-2014, 12:46 PM
hydell3's Avatar
i made a post about it its the gsr tear down and rebuild
Old 07-19-2014, 06:48 PM
tollickj's Avatar
Yeah man... I didn't read it fully and I didn't see that you found that in your oil pan... The owner before you either didn't properly lube the washer in place right/placed on the wrong side or paid someone to do the job and messed it up... If it's a knock other than the thrust washer... When disassembling the motor check your crank for any damage from spun bearings (main caps or pistons). If your bearing is bad hopefully your crank isn't done. If there good I would check the pistons and try to sell the block and crank and make a few bucks to use for your Gsr build.
bLu92bUbbLe
10
04-27-2009 02:50 AM
andrewasf77
25
05-19-2004 09:51 AM
Kimbo
04-25-2003 09:42 AM
blkgsr03
09-19-2002 10:05 AM
EGh22aEG
04-15-2002 07:00 PM
Quick Reply: anyone know what this part is please !?!?!?!
