2006 Accord V6 PCV valve check?
What's the best way to check the PCV valve on the V6 engine? Can I shake it and listen for a rattle, or is there a better test to do? The oil is running low, but no leaks. I checked one of the spark plugs and it looks fine, no oil on it or damage.
Re: 2006 Accord V6 PCV valve check?
if u use needle nose pliers to pinch the PCV hose u should hear a "click" sound indicating that the valve is working properly and cant figure out what is blocking the hose
swertepinoy
10-12-2009 02:50 PM
