Honda S2000 Honda S2000
How do I reset my srs light
Old 07-16-2014, 08:06 PM
Ajr
Ajr's Avatar
Default How do I reset my srs light
My STS stay on how do I reset it
Old 07-31-2014, 01:30 PM
Jacob10's Avatar
Default Re: How do I reset my srs light
Here are the steps that I use to reset the SRS light on my 2000 Honda Accord.
1. The plug is located below the dash on the drivers side. It is against the right side plugged into a panel. It does not have an electrical connection to that panel. I leave mine unplugged and hanging for easy access if I need to reset the SRS light again.
SRS light reset plug on a Honda Accord
2. You will need a paperclip, piece of wire or something that can easily be used to short out the plug. I use a paperclip. With the key off, connect the paperclip to both ends of the plug. I am connecting the circuit in a specific order to reset the SRS light.
3. Hold the wires together (short it) while you turn the ignition on (turn key to on position, not start). The SRS light will come on for a couple seconds and then go out.
4. When the SRS light goes off, disconnect (un-short) the wires.
5. The SRS light comes on again, connect the wires again.
6. The SRS light will then turn off. Disconnect the wires. The SRS light should blink twice and your SRS light and system will be reset.
Hope this helps.
Old 08-04-2014, 01:47 PM
pixelgrinder's Avatar
Hope this helps.
This should work for the S2000, I'll try this when I get home. Thanks
Old 08-04-2014, 05:29 PM
Ajr
Ajr's Avatar
I try it on my s2000 and the light stays on what else can I dO
dragallmotor24
Honda Civic (2001 - 2005)
41
03-18-2013 02:25 PM
undrh2o
10
12-19-2009 11:42 AM
t-town_ep
07-25-2007 05:11 AM
SiR AuToBoT
04-05-2005 05:50 PM
DumpedSi
09-11-2003 08:42 PM
Quick Reply: How do I reset my srs light
