92' si h22a vtec wire-up?
Old 07-15-2014, 10:15 AM
mrbyrne9831's Avatar
Icon2 92' si h22a vtec wire-up?
So every thread i've checked is useless to my cause. Need help with tryin to find out how to wire it in since my car was never pre-wired to begin with. Any help would be great! Pictures would be even better!
Old 07-15-2014, 01:43 PM
bairdandrew77's Avatar
Default Re: 92' si h22a vtec wire-up?
A4 is for the VTEC solenoid and D6 is for the VTEC pressure switch. Run a wire from each of them to their respective areas.
Old 07-17-2014, 12:57 AM
holmesnmanny's Avatar
You will pop open the back of the ecu connectors and slide the pins in fully and then just close it up and you're done.
You can get a kit from axidworks. Just google his name.
Old 07-26-2014, 04:28 AM
luzer91's Avatar
http://hondaswap.com/threads/how-to-wire-vtec.40811/
hope this helps, its just 2 wires one is a ground and one goes to ecu.
phearable.net has some great info also. hope this helps. I can go back and look at mine if youneed me to, 4ws models are not pre-wired ether, olny plain si's '93 up.
ellywyte
03-30-2011 02:28 PM
nothing_shocking
02-17-2009 12:16 PM
fryman
09-24-2008 10:07 AM
bburtonsk8r2
11-09-2005 02:16 PM
visiontuning
09-23-2002 01:32 PM
Quick Reply: 92' si h22a vtec wire-up?
