DRL dash light
Old 05-08-2014, 01:35 PM
moss500's Avatar
Default DRL dash light
I had the DRL dash light on last week and the passenger bulb was out. Replaced both bulbs with Osram. I noticed the passenger bulb was broken, not just burned out.
With new bulbs I still have a DRL light on my dash. Stays on when parking lights are on. It only goes away when I turn the night lamps on.
I thought it was normal to be dimly lit, but the DRL light isn't dim. Is there a relay or wire issue here?
Old 05-08-2014, 01:38 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: DRL dash light
Daytime Running Light? Uh, our cars don't have that stock, unless there's something you're failing to tell us.
Old 05-08-2014, 04:06 PM
The Grumpiest
grumblemarc's Avatar
Um, what Civic do you have that has DRLs?
Old 05-08-2014, 05:13 PM
moss500's Avatar
It's a Canadian car. All sold after 1990 required DRL here as far as I know.
Anyway I think I have it figured out.
Old 05-08-2014, 05:24 PM
The Grumpiest
Old 05-08-2014, 05:34 PM
moss500's Avatar
I didn't realize the US cars didn't come with DRL. I'm not from the US.
It's a 92 Civic (listed in garage and signature..) model DX
The dash light increases in brightness when the high beams are on. In a garage the "dim" light appears bright.
In the sun the light is too faint to see. Otherwise the dash light is coming and going.. I'll know after I drive again tomorrow morning.
Old 05-08-2014, 05:46 PM
Former User's Avatar
I don't see a DRL dash indicator light in the circuit diagram. Can post pictures?
Old 05-08-2014, 06:04 PM
moss500's Avatar
Sorry it's the high beam indicator not DRL.
First photo is with the lights off (except DRL). It stays like this when the parking lights are on.
When the night lights are on, it turns off. Unless of course the high beams are turned on. Second photo shows the high beams on with night lights. As you can see it's brighter.
I could've took a photo of the night lights without the high beams on but didn't think to.
Old 05-08-2014, 06:08 PM
The Grumpiest
I don't understand a word you've said. Someone translate?
Old 05-08-2014, 06:09 PM
Test the light switch. Might be bad. Try cleaning contacts.
girlscandothis
Honda CR-V & Element
06-03-2019 09:14 PM
thunderboy
Honda Civic (2006 - 2015)
11-08-2013 04:25 PM
nhldogg
02-22-2010 01:50 PM
simike
08-05-2002 01:37 PM
Quick Reply: DRL dash light
