Pros/Cons of Resonator Removal
Old 10-30-2002, 08:28 AM
kingseth2's Avatar
Default Pros/Cons of Resonator Removal
I did a search on the subject and found a lengthy thread about removing the stock intake resonator for the ITR https://honda-tech.com/zerothread?id=178659
I have a 98 I4 Accord and would like to know how removing the resonator will 1) affect my gas milage and 2) will removal add or detract from the performance of my engine both in terms of lower end throttle response (I am aware that colder air improves the upper power ban) and the lasting integrity of the engine.
Thank you
Old 10-30-2002, 08:40 AM
Razor's Avatar
Default Re: Pros/Cons of Resonator Removal (kingseth2)
nothing will happen to your car, it will free up a hp or two...and even more if you get a k&n dropin filter like i did. for ITR's, the stock intake was designed so well that if you remove the resonator, you will lose hp. but with accords, you will gain.
Old 10-30-2002, 08:47 AM
kingseth2's Avatar
Default Re: Pros/Cons of Resonator Removal (Razor)
Thank you Razor
k20prsi
Honda Civic (2006 - 2015)
24
04-14-2011 12:00 AM
otacon122
10-16-2007 01:07 PM
mnaines
12-12-2006 04:58 PM
ghost SHell
05-16-2005 12:47 PM
Flux
05-03-2002 11:48 AM
Quick Reply: Pros/Cons of Resonator Removal
