Applying liquid gasket to bolt threads rear main seal?
Old 04-16-2014, 07:20 PM
JohnnyEF's Avatar
Default Applying liquid gasket to bolt threads rear main seal?
I installed some new seals on a d16z6 motor and ready to install the motor in my civic hb. I have overlooked an important step when installing the rear main seal housing on the motor. According to the helms manual I should have applied liquid gasket to the rear main seal housing bolts. Will most certainly leak without the liquid gasket applied to the threads. Any advice would be appreciated.
Old 04-16-2014, 07:24 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Applying liquid gasket to bolt threads rear main seal?
Being you haven't installed the motor, I would back track to the point of being able to pull those bolts and gasket them up and reassemble.
By the looks it's mainly just timing belt work to get to and put back together.
B serious's Avatar
The motor isn't installed. So....this seems like an easy fix.
Use Hondabond, for God's sake.
Old 04-16-2014, 09:39 PM
Fish Twig
tony_2018's Avatar
Everybodies on the cheap cheap, if he can't afford hondabond he probably didn't use the oem seal.
OP just remove the bolts and apply it since the motor is still out. If you already dropped the motor in then you'll either have to pull the motor or pull the tranny to get to it.
Old 04-17-2014, 10:31 AM
JohnnyEF's Avatar
I did use hondabond and new OEM rear main seal. Do I just unbolt and add the hondabond to the threads? Wouldnt I have to remove the rear main seal housing and reseal the housing again with new hondabond?
Old 04-17-2014, 10:41 AM
myEKsedan's Avatar
why would you have to remove the housing? just remove one bolt at a time...criss cross pattern..
Old 04-17-2014, 11:21 AM
B serious's Avatar
Wait. What did you hondabond? You can't just remove the bolts and hondabond them.
You're not trying to seal the threads. Applying it to the threads transfers gasket material to the gap between the hole and the bolt.
You're trying to seal the flange of the housing AND the bolt holes.
You most likely put too much gasket material on there anyway (common). In which case, it would have squished itself into the bolt holes. You can take that chance if you're confident.
Otherwise, take it apart. Clean the surfaces back down to bare metal. Then re-apply the honda bond to the correct places.
Hopefully you didn't remove that housing just to put in a rear main seal.....
Old 04-17-2014, 06:23 PM
canadaek's Avatar
For my y7 it was cheaper to buy the housing with seal then just the seal alone.
Old 04-17-2014, 07:36 PM
B serious's Avatar
The seal is like $15 or something thru honda....
Old 04-18-2014, 03:02 AM
Fish Twig
tony_2018's Avatar
The image does state to apply it to the bolt thread but from what I've seen the don't apply a lot, just a tad bit. I guess what they are trying to do is the same thonda locktite does.
Old 04-18-2014, 06:12 PM
JohnnyEF's Avatar
I used hondabond between the rear main seal housing and the block.
I see that makes sense. Just to be safe I probably will apply enough hondabond throughout the bolt to ensure the gap is filled. I am afraid if I just apply to the threads, there may not be enough material squeezed to level of where the block and housing meet.
Not really sure if I put enough, so I will remove the existing hondabond from the block/housing and reapply the hondabond between the housing/block and apply the hondabond to the bolts.
I wanted to reseal the rear main seal housing.
Thank you, your input was very informative.
Old 04-18-2014, 06:17 PM
JohnnyEF's Avatar
When you say seal, are you referring to the rear main oil seal? When you bought the housing it came with the rear main oil seal?
1990 CB7
02-27-2017 11:40 AM
EJ1_95Cwallace
09-04-2008 11:05 AM
GSR_hatch936
14
10-30-2007 11:09 AM
s2kkid
07-20-2005 09:26 PM
jdmspoonpower
05-12-2005 10:00 PM
Quick Reply: Applying liquid gasket to bolt threads rear main seal?
