fog lights not working?
2006 tsx stock oem fog lights not working.... the fuse is ok wheres the relay for the foglights if they even have one if this isnt the issue where sound i look?
Re: fog lights not working?
Hard to say without more info, could be a couple of things. Have you tested the fuse to see if it's getting power? That will tell you if the problem is upstream or downstream. If the fuse isn't getting power, it could be a relay or switch issue. If the fuse is getting power, then it could be a harness issue, or the bulbs are burned out.
Frost7177
07-16-2009 02:05 PM
built562
11-29-2003 05:29 PM
