Clutch Master Cylinder Installation; Stream Of Fluid, No Compression On Clutch
Old 03-02-2014, 01:21 PM
Jimmydean771's Avatar
Icon3 Clutch Master Cylinder Installation; Stream Of Fluid, No Compression On Clutch
I got a '95 Accord EX 2.2 5-speed and just replaced the clutch slave cylinder and master cylinder and put my finger over the plug extremely tight and bled it multiple times, then bled normally. We're getting nothing but fluid shooting out, but there is no compression on the clutch whatsoever and it's sticking on the floor. I have to use my hand to pull it back up to pump it. We're on our last nerve, taking a break, and I really need your guys advice? We were told there's some kind of special way to bleed a clutch master cylinder after bench bleeding, but not sure. PLEASE ADVISE.
Old 03-02-2014, 05:13 PM
Default Re: Clutch Master Cylinder Installation; Stream Of Fluid, No Compression On Clutch
Figured it out. If you're installing a clutch master cylinder, before you waste half a gallon of brake fluid, ADJUST YOUR PUSH ROD!
mikep_95133
12-22-2013 12:35 AM
92eg6lsvtec
05-20-2006 05:56 AM
RaceMyGhost
12-26-2005 09:51 PM
714JDMBB4
08-29-2005 05:34 PM
phantom_sol
10-08-2003 08:14 PM
Quick Reply: Clutch Master Cylinder Installation; Stream Of Fluid, No Compression On Clutch
