What trans fluid to run in b series liberty face plate gears
Old 02-22-2014, 02:50 PM
  #26
Aquafina's Avatar
Default Re: What trans fluid to run in b series liberty face plate gears
Originally Posted by NAH2B
lol that's funny considering hes been on Honda mtf for 2 seasons working flawlessly.
and hes not the only one
How does the gear wear look?
Old 02-22-2014, 03:01 PM
  #27
choadsi's Avatar
trans fluid is not the reason you broke a gear on the dyno. I don't know of many guys "bangin" gears under load on the dyno
not "bangin" gears under load though it was on a dyno pak which aren't friendly to drivetrain anyway....but the stock trans was under the same load on the same dyno with the same tuner, 3 hard sessions later, still running strong on torco RTF....but run what you want some people have different experiences with different fluids that was just my .02 on what fluid to run and my so far success with RTF... if she ***** out again I'll def let you guys know
Old 02-22-2014, 04:28 PM
  #28
blade0314's Avatar
All my gears looked brand new
Old 02-22-2014, 06:49 PM
  #29
NAH2B's Avatar
the gears themselves never have any wear and always look new
the stock dog teeth, hubs and sliders obviously wear over time no matter what fluid you run.
10k+ rpm around 350whp n/a dynojet
Old 02-22-2014, 06:53 PM
  #30
NAH2B's Avatar
that's what I mean. obviously you weren't bangin gears on the dyno. so your gear broke while already engaged during the pull. theres no way the fluid caused it to break. the fluid isn't going to weaken the material.
Old 02-22-2014, 09:09 PM
  #31
choadsi's Avatar
heat is what broke my gear...RTF reduces gear box temperatures and helps with high load, high torque, and high speed applications...like I said run what you want to, this is my fluid of choice for now and what I will run in my face plated trans
Old 02-23-2014, 05:10 AM
  #32
NAH2B's Avatar
I am happy to agree to disagree
Old 03-11-2014, 10:06 AM
  #33
choadsi's Avatar
Well I said I'd give you update...car came off the dyno last night no issues with the trans on Torco RTF...shifted nicely and held up to the power...run what you want to personally I'm sticking with this, yeah it might be more expensive than the Honda MTF but what's the price on a trans rebuild
Old 03-12-2014, 05:37 AM
  #34
Pro-SeriesFab's Avatar
You'll find that mentality everywhere . . . what can I run vs. what should I run . . .
Old 03-12-2014, 08:27 AM
  #35
Honda Bull's Avatar
While I know very little about that gentleman's setup and his transmission's history, you should be verey careful about that statement you just made. Fluid may not weaken a material in and of itself, but it does guard that material by providing cushion in the form of shock additives, ZDDP content, and friction reduction. All of which play a part in a tooth's lifespan.
Run Honda MTF on a 400+ wtq, straight cut gear set and see what happens in a hurry to the tooth faces. I assure you the Honda fluid (and several others) does not protect against the sliding action of those gear teeth.
Old 03-12-2014, 05:48 PM
  #36
NAH2B's Avatar
I understand this. I did not recommend Honda mtf for straight cut gears...
he said his gear broke on the dyno, meaning there was no shock load applied to the gear. unless he shifted gears during the pull...unlikely, hence the "banging gears" statement.
Old 03-12-2014, 07:41 PM
  #37
choadsi's Avatar
true no shock load was applied but a load was applied due it just being on the pak...the fluid creates a nice cushion between the main and counter shaft gear stacks...along with helping to lower the trans temp as a whole is why it is better overall than MTF, but i understand what you mean and hope now it will help when it comes time to shift going down the 1320...fingers crossed
Old 03-13-2014, 05:25 AM
  #38
Runnerdown's Avatar
Dynapak will load gears plenty hard enough, no shock needed to break gears. Honda oem mtf is junk, any of the torcos or redline fluids should work fine.
Old 03-14-2014, 06:30 AM
  #39
JayWest's Avatar
Torco RTF
Old 04-19-2014, 09:56 AM
  #40
94 ls teg's Avatar
what kind of fluid did u end up going with?
Old 04-19-2014, 11:25 AM
  #41
blade0314's Avatar
Using Relight lightweight shockproof and it's working great 10krpm wide open throttle shifts
Old 04-19-2014, 01:18 PM
  #42
AllShowNoGo727's Avatar
I just got a liberty face plate trans with 5th gear cuff and wavetrac diff I bought the Torco RTF from the reviews I have seen on here, Hope it works for me.
Old 04-19-2014, 04:26 PM
  #43
EFTRIKCRX's Avatar
I have a faceplated tranny I run redline ns my first one got 70+ passes and whipped out 2nd got a new 2nd and main shaft cryo treated and only lasted 7 passes and wiped out again
Old 04-19-2014, 04:55 PM
  #44
94civiccupew/b7's Avatar
running torco rtf here as well. the stuff doesn't seem that ridiculously thick. shifts perfect once its warmed up a little. I'll pay the extra for the added assurance and peace of mind
SUP!reme
Transmission & Drivetrain
11-08-2013 05:43 PM
240 killer
11
11-07-2012 06:47 AM
redboy183
11
01-15-2008 06:31 PM
Hockey27925
10-19-2004 02:03 PM
Philip
12-29-2003 06:19 PM
Quick Reply: What trans fluid to run in b series liberty face plate gears
