Possible differential problem? Im stumped..
Old 02-10-2014, 11:34 PM
Jhofbauer94's Avatar
Default Possible differential problem? Im stumped..
I have 91 Acura Integra, was driving today and all of a sudden there was a knocking coming from (what sounded like) back behind/down under the headunit area.. Could hear it but not yet feel it. I started heading home when all of a sudden it went from knocking to a banging/rumble. So bad to where I pulled over immediatly. I noticed it only did it when I was accelerating, not when I was idling.. At first I thought it could maybe be a shifted axal or something along those lines, but like I said, it only does it while accelerating and not when im not in gear and rolling, so I ruled that out. Help me! Input is greatly appreciated.
Old 02-11-2014, 03:59 AM
Runnerdown's Avatar
Default Re: Possible differential problem? Im stumped..
Best bet is to jack it up and start grabbing thing like the axles and see what is out of place. Give everything a good shakedown.
Early cable transmissions have really weak differentials and can suffer diff pin failure but theres no point in jumping to any conclusions yet.
Old 02-11-2014, 11:35 AM
Yeah, thats my plan today. Just wanted to get some input before I do that or if I cant find anything physically wrong on it. Thanks man.
Old 02-11-2014, 05:54 PM
F22Master's Avatar
Had the same issue with a B16 S1 cable transmission. It would go away by putting a new (freshly reman'd from autozone) axle in it (passenger side), but would come back anywhere from 500-3000 miles later. Pretty sure it was the diff. With the front tires off the ground, and the car in gear, there was ~30* of slop between each wheel when rocking one side back and forth. Most of that seemed to be coming from the diff, I think it's called backlash. I have a newer diff from a LS trans that Im gonna put in and see if it solves my problem.
Old 02-11-2014, 06:41 PM
How much are diffs? And thanks man, let me know if that works out.. I cant stand this.
Old 02-12-2014, 01:37 PM
F22Master's Avatar
You can usually find them for $50-100 used on ebay.
TeggyTitan831
07-19-2018 10:20 AM
88crxsir
Suspension & Brakes
10
09-14-2005 12:49 AM
BlackNoise
03-20-2003 09:33 PM
ssblue
07-10-2002 06:28 AM
Quick Reply: Possible differential problem? Im stumped..
