Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
2006 TSX power seat wiring pinout?
Old 02-05-2014, 05:51 AM
miahallen.on.ln's Avatar
Default 2006 TSX power seat wiring pinout?
Hey TSX fans,
I'm building a racing simulator and I bought an 04/05 TSX drivers seat to use for it (link to my build if you're curious). I have an aux 12V power supply to hook it up so I can make position adjustments, but I don't know what wires need to be hooked up.
I'm wondering if anyone can help me identify where I need to plug in my 12V & ground lines to make the seat movements function. Obvoiusly, I'm not concerned with the seatbelt sensor or the airbag, and I don't care about the seat heater either. Thanks
http://www.thewayiplay.com/mainforum...p?topic=2554.0
Old 02-11-2014, 05:26 PM
Default Re: 2006 TSX power seat wiring pinout?
Here is a video showing where I am at with this project, any help would be appreciated
Old 02-12-2014, 02:05 PM
UTAH TSX's Avatar
Here you go
Old 02-12-2014, 02:10 PM
UTAH TSX's Avatar
and
Old 02-12-2014, 07:17 PM
Dude...sweet!!! But a little too slow. I ended up cutting out the control box
It turns out I was able to bypass the control board and wire my amp directly to the DPDT switch PCB in the side of the seat...
I started by probing all the contacts with the switches in all positions...
I don't have a clue how it worked from the factory, but when I wired an additional two ground wires to this board (into pins which were unused) I was able to get full functionality.
After getting that figured out I just needed to mount the new seat and wire it up to my rig.
Check my build log here for the final result.
http://www.gtplanet.net/forum/thread...3#post-8507004
Old 02-13-2014, 08:29 AM
robpp's Avatar
looks good.
my bud Paul in the UK has a similar setup.
100 inch screen. he does all the F1 stuff.
pretty cool when you get the actuators moving LOL
GL
Old 02-13-2014, 12:10 PM
Thanks again robpp, it would have been nice to preserve the original control box for possible future resale....but I think I'll probably keep this seat for a while anyway :-)
GThonda
07-06-2010 07:22 AM
ljlyman
10-04-2008 01:16 PM
di rang
08-11-2004 01:18 PM
RacerMike
02-14-2003 08:42 AM
Quick Reply: 2006 TSX power seat wiring pinout?
