progress CS-II Coilover Spring rate
Old 01-30-2014, 08:45 AM
Freemananana's Avatar
Default progress CS-II Coilover Spring rate
Looking for some quick opinions. I read the website and I'm pretty sure I'm in the 350/350 spring rate range. I do, on occassions, drive this car to work though. Which is only 2 miles or so, but the roads aren't very smooth. Would I still be okay with 350/350 or should I step it down to 350/250?
The car is a 1989 hatchback, boosted B16A, intended purpose is drag racing. I don't care for any particular look, but I do want some decent, entree level, performance coilovers.
Thanks
http://www.progressauto.com/products.../productID/778
STREET PERFORMANCE:
These kits use 350# front and 250# rear springs. This calibration rides well on uneven road conditions if set up at a reasonable ride height around 1.0 in. to 1.5 in. less than OEM. Expect a dramatic improvement in handling capability and steering response. This is the choice for sport-tuned "daily drivers".
STREET-SPORT
These kits use 350# front and 350# rear springs. This calibration is more aggressive and transitions faster for the "sport" driver. Expect a dramatic improvement in handling capability and response, and some reduced ride quality. This is the great choice for "street and track day" multi-use vehicles, and vehicles driven hard on better (smoother) roads.
Old 01-30-2014, 09:30 AM
Charlie Moua's Avatar
Default Re: progress CS-II Coilover Spring rate
350/350 is 100% fine.
my ef is only lowered by 1.5" with the csII kit.
the wife and i have taken the car out on date nights, midnight drives on curvy & bumpy roads.
wify approved.
we are considered old too.... 31.. lol
Old 01-30-2014, 09:46 AM
wify approved.
Sounds perfect then. Wife approved isn't even necessary. I don't really care for the look of being low, but the performance aspect. So this should be great. Going to order a set shortly.
Old 01-30-2014, 10:08 AM
mar778c's Avatar
I run the AutoX kit on my EF 500/350. It makes the car feel solid.
I also have a 350/200 on my integra. A very nice ride. I don't race the integra.
Also, if Charlie is old then I must be ancient....46... lol.
Old 01-30-2014, 10:20 AM
500/350! Hot dog! These only go up to 450/500. Would 450/350 be any better? This car doesn't see a lot of roadage. It's my daily driver...sort of. I have another car that gets 35 mpg and has A/C. So I tend to drive that more than this now days.
I'm honestly open to spring rate suggestions. I thought 350/350 would be a good start. It is for 'drag racing' mostly. So I think a higher rear would help keeping the nose down during launch. Cornering aspects are NOT nearly as important to me.
EDIT: Had to add the not portion.
Old 01-30-2014, 10:44 AM
GagnarTheUnruly's Avatar
Stiffer rear rates are better for drag racing I think because they result in the chassis responding quicker to weight transfer. I'm not sure if extra compliance in the front helps anything although Progress recommends 350/500 for drag racing (with the CSIIs).
However I think for DD 350/350 is probably the best compromise. It'll be safer on the road, too. There is room for opinion on how tolerable the 350 rear rate is. Less room for opinion on the 500 rear. Certainly some people DD 500 rear but I would not want to. Particularly on a car as light as your hatch.
Old 01-30-2014, 10:48 AM
Could you explain how the 500 rear rate would effect my daily driver on the street? You seem to know more than I do about this. I'm definitely up to being schooled on a subject I am just starting to tackle.
Old 01-30-2014, 07:40 PM
mar778c's Avatar
500 in the rear is fine for drag racing but it will make the car very twitchy. In the rain, the car will be not so fun to drive.
Old 01-31-2014, 02:52 AM
I'll keep that in mind.
Honestly, 350 rear compared to the 110 stock should be enough of an upgrade. My car makes less than 300 HP.
Old 02-02-2014, 05:11 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
350/350 is perfect for a dd. Very comfortable. I recently upgraded the rear to 450 since I autox it a lot. On the hwy, the back end tends to have a little bounce when going overpasses.
Old 02-03-2014, 08:45 AM
Could I get a couple quick opinions on 350 vs 500 for drag racing. Obviously, 500 will be better, but how much more based on the fact that I have a 2300 lb car (with me) that only makes 280 whp.
Old 02-03-2014, 09:35 AM
When I was 350/350, I was having issues getting into the 13's. After upgrading the rear to 450, I ran my best time of 13.6. That's with prob 160 whp.
Old 02-03-2014, 10:51 AM
Dang. Seriously? I need to work on my driving... I don't want to talk about what I run. Much better than the 19 stock the B1 put down, but nothing to write home about.
So, with 450, how was the ride? 1-10
1. Awful, eBay coilover ride or 4x4s instead of shocks.
5. Stock for being 20 years old.
10. Brand new high end luxury car. Pretty much like riding an elevator.
I am looking to be in the 3~ range. Which is rough, not good for potholes, but with a decent seat will be more than doable for regular driving.
Old 02-03-2014, 04:43 PM
The 350/350 were comparable to the ride of my lexus minus all the body roll. The 450 is great but at hwy speed, you get a little bounce. My only complaint. 350/450 I would rate a 7.5-8.
Old 02-04-2014, 10:04 AM
Honestly. I think I may go with 350/500 then. Can't be any worse than my Bug. I don't do a ton of highway driving. But a little bump can't be thaaaaat bad.
Metal Head
Suspension & Brakes
12-03-2007 11:57 AM
dc2turbo
05-18-2006 09:55 AM
Dyzee
05-01-2004 05:35 PM
conesmasher
01-22-2003 07:38 PM
rOby
10-03-2002 12:05 PM
Quick Reply: progress CS-II Coilover Spring rate
