Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
MAXIMUM TRACTION AND POWER TO THE GROUND - Guaranteed!
Old 01-27-2014, 04:13 AM
MFactory's Avatar
Icon7 MAXIMUM TRACTION AND POWER TO THE GROUND - Guaranteed!
Hello Honda-Tech,
- Are you sick & tired of the "One Wheel Wonder" syndrome?
Just imagine it; You're sitting at the line, waiting for the Green to light up on the tree, you disengage the clutch then bam, big cloud of tire smoke but you're not going anywhere! You're not the first, and most certainly not the last, to experience the One Wheel Wonder syndrome
Or how about when you're going through that tight apex, approaching the exit point, but no matter how hard you accelerate, the competitor who was right up against your rear going into the turn is now leaving you for dust as you exit? He obviously has an Limited Slip Differential (it's never the driver :p)
- If the answer is YES, MFactory Competition Products is the answer to your prayers!
Introducing the MFactory range of Forged Limited Slip Differentials. By precisely controlling the transfer of torque between the left/right wheels, you will gain maximum traction, allowing you to eliminate the "One Wheel Wonder" syndrome during drag racing and power through those tight corners on the circuit with maximum exit speed.
Helical LSD
Description: Also known as a "Torque-Biasing Differential", the 2nd Generation MFactory Helical LSD is lighter, stronger and more efficient than any other Helical LSD on the market today! Through the use of maintenance-free Gears, this eliminates the need for special fluids & rebuilds associated with plate-type LSDs. Lock-free operation also ensures no adverse affect to steering response
Suitable for: Street Cars, Drag Cars, Occasional Road/Race
Power Rating: 1000whp+ (As proven in the world's fastest Hondas)
Warranty: Lifetime Warranty (even if raced!)
Why MFactory?: Our Helical LSD's have been proven to be Stronger, Lighter and have better tolerances than our competition
Feel the Torque™ Guarantee: An industry first! We stand by the quality of our products so much and, fully believe that you, our valued customer, will be fully satisfied with your Helical LSD that if, for whatever reason, you are not happy with your purchase, you may return the product to us for a full refund (excluding shipping costs) within 30 days of the purchase date!
Fitments:
Part# MF-TRS-05B16 - B16A (Cable/Hydro)
Part# MF-TRS-05B18 - B16B/18C
Part# MF-TRS-05D15 - D16 (Cable/Hydro) - Black Speedo Gear - 40mm Bearings
Part# MF-TRS-05D15A - D15/16 (Cable/Hydro) - White Speedo Gear - 35mm Bearings
Part# MF-TRS-05D15Z - D15/16 ZC (Cable/Hydro) - 40mm Bearings
Part# MF-TRS-05H22 - H22A/F20B
Part# MF-TRS-05K20 - K-Series
Part# MF-TRS-05L15 - FIT GD3
Part# MF-TRS-05L15A - FIT GE8
Part# MF-TRS-05R18 - R18A
Part# MF-TRS-05LEA - CR-Z
Part# MF-TRS-05F20 - F20/22C
NEW: Stage 1 Race Pack Upgrade now available for Honda B-Series, K-Series and H-Series Fitments. Designed for more aggressive cornering by raising the torque bias from 66% to 75%. $100 updrade applies at time of LSD purchase, or $249.95 when purchased separately (includes new internal gears, washers & bolts)
Price: All fitments $699.95 inc FREE Shipping within Mainland US
Package Deal 1*: Add a set of Differential Bearings for only $34.97 ($41.97 for B18C, $89.96 for H22A) at time of purchase. That's a 30% Saving!
Package Deal 2*: Get 6L of Torco MTF for only $37 or 6L of Torco RTF for only $78.10 when ordered at the same time. That's a 35% Saving! Mainland US Only. $18.95 shipping applies
Package Deal 3*: Get an additional 10% discount off our Carbon-Composite Synchros, Synchro/Slider Kits and Master Rebuild Kits when ordered at the same time
* Package Deals can be combined
Metal Plate LSD
Description: Also known as a "Clutch Type" or "Salisbury Type" differential, the MFactory Metal Plate LSD puts the power-to-the-ground and maximises your vehicle's traction where conventional Torsen LSD's fail. Unlike a Torsen style LSD, when one wheel loses traction completely (e.g wheel lifts off the ground or axle failure), the 2nd wheel will still have drive and you will not be stranded in the heat of the moment. The Metal Plate LSD is by far the best performing Limited Slip Differential available for a dedicated circuit or rally car
Suitable for: Road/Race Cars
Power Rating: ~500whp
Warranty: Lifetime Warranty (exc. Plates & Springs)
Why MFactory?: Unlike our competitors who utilize the out-of-date external "Cone-Washer" pre-load system, the MFactory Metal Plate LSD's utilize 21st Century technology with it's internal "Coil-Spring" pre-load system, which provides gradual plate engagement (not the on-off switch like our competitors) and ensures minimal powerloss and maximum response. Our Metal Plate LSD's have been proven in the fastest Road/Race Hondas in the US & Asia-Pacific
Fitments:
Part# MF-TRS-10B16 - B16A (Cable/Hydro) - 1.0way (2 Angle)
Part# MF-TRS-10B16A - B16A (Cable/Hydro) - 1.0/1.5 Way
Part# MF-TRS-10B16B - B16A (Cable/Hydro) - 1.5/2.0 Way
Part# MF-TRS-10B18 - B16B/18C - 1.0 Way (2 Angle)
Part# MF-TRS-10B18A - B16B/18C - 1.0/1.5 Way
Part# MF-TRS-10B18B - B16B/18C - 1.5/2.0 Way
Part# MF-TRS-10D15 - D16 (Cable/Hydro) - 1.0 Way (2 Angle) - Black Speedo Gear 40mm Bearings
Part# MF-TRS-10D15A - D16 (Cable/Hydro) - 1.0/1.5 Way - Black Speedo Gear 40mm Bearings
Part# MF-TRS-10D15B - D16 (Cable/Hydro) - 1.5/2.0 Way - Black Speedo Gear 40mm Bearings
Part# MF-TRS-10H22 - H22A/F20B - 1.0 Way (2 Angle)
Part# MF-TRS-10H22A - H22A/F20B - 1.0/1.5 Way
Part# MF-TRS-10H22B - H22A/F20B - 1.5/2.0 Way
Part# MF-TRS-10K20 - K-Series - 1.0 Way (2 Angle)
Part# MF-TRS-10K20A - K-Series - 1.0/1.5 Way
Part# MF-TRS-10K20B - K-Series - 1.5/2.0 Way
Part# MF-TRS-10F20 - F20/22C - 1.0 Way (2 Angle)
Part# MF-TRS-10F20A - F20/22C - 1.0/1.5 Way
Part# MF-TRS-10F20B - F20/22C - 1.5/2.0 Way
Price: All fitments $899.95 inc FREE Shipping within Mainland US
Package Deal 1*: Add a set of Replacement Plates for only $119.96 at time of purchase. That's a 20% Saving!
Package Deal 2*: Add a set of Differential Bearings for only $34.97 ($41.97 for B18C, $89.96 for H22A) at time of purchase. That's a 30% Saving!
Package Deal 3*: Get 6L of Torco MTF for only $37 or 6L of Torco RTF for only $78.10 when ordered at the same time. That's a 35% Saving! Mainland US Only. $18.95 shipping applies
Package Deal 4*: Get an additional 10% discount off our Carbon-Composite Synchros, Synchro/Slider Kits and Master Rebuild Kits when ordered at the same time
Already have an LSD in your transmission? Or even one that failed on you and is now just an expensive paper-weight?:
Depending on the type/brand, you may be eligible for the MFactory Refugee Program, a unique service which allows you to trade-in your old/damaged product for a brand-new MFactory equivalent at significant discount. Now you no longer need to have those expensive paper-weights taking up precious storage space! For more details, please CLICK HERE
For further information, please CLICK HERE to Contact Us, or send us a PM
About MFactory
Established in 2004, MFactory Competition Products has since grown to become one of the Leading Global Manufacturers of high performance off-the-shelf aftermarket transmission components, with our large range of Forged Final Drive Gears, LSD's and Close Ratio Gears offering enthusiasts undeniably THE most cost-effective method of performance improvement, far surpassing that of conventional engine tuning.
Being a specialist in this industry requires focused knowledge that can only be gained through years of first-hand testing and tuning experience. Challenging the old adage that 'there is no replacement for displacement', MFactory Competition Products have become a prominent figure in the highest levels of Motorsport, with class-leading recognition the world over in Circuit Racing, Drag Racing and Rally.
Every product within the MFactory catalog is designed in-house in the USA and manufactured in-house to our own specifications at both our US R&D Facility and our multi-million dollar, state-of-the-art, ISO Regulated Taiwan factory, before being tested & developed in the real-world on state-of-the-art race vehicles from North America, Europe and Asia-Pacific. Our products are designed from the beginning to surpass the competition. Why choose MFactory? Here's why:
Official OEM to Honda of America's Motorsports Divisions
World's Largest Manufacturer of Forged Performance Transmission Components for Japanese and European Automobiles
North America's Largest Manufacturer of Limited Slip Differentials for Japanese and European Automobiles
North America's Largest Honda/Acura Performance Transmission Specialist
The World's Only Performance Transmission Manufacturer to offer a 30 Day Money Back Guarantee!
The World's Only Performance Transmission Manufacturer to offer a Discounted Trade-in for a Competitors Product; even if it's damaged!
Want more Information? To view our complete company profile and manufacturing processes, please CLICK HERE to visit our website
MFactory is offline
Old 01-27-2014, 05:05 AM
whitesihatch's Avatar
Default Re: MAXIMUM TRACTION AND POWER TO THE GROUND - Guaranteed!
bump for a great lsd, have the helical in my car and it puts the power to the ground, no bs.
whitesihatch is offline
Old 01-27-2014, 08:03 AM
MFactory's Avatar
Thank you for your support
MFactory is offline
Old 01-29-2014, 08:20 PM
MFactory's Avatar
Keep the orders coming
MFactory is offline
Old 01-30-2014, 08:26 AM
MFactory's Avatar
If you have any questions, please feel free to send me a PM.
To order online, please click here: www.teamMFactory.com
MFactory is offline
Old 02-03-2014, 08:26 AM
MFactory's Avatar
North America's #1 Selling Honda Differential
MFactory is offline
Old 02-03-2014, 08:31 PM
MFactory's Avatar
MFactory is offline
Old 02-04-2014, 08:56 PM
MFactory's Avatar
MFactory is offline
Old 02-07-2014, 10:03 AM
MFactory's Avatar
Contact us for our Hero Discount (Emergency Services, Military)!
MFactory is offline
Old 02-13-2014, 09:20 AM
MFactory's Avatar
All orders shipped out
MFactory is offline
Old 02-15-2014, 08:48 AM
MFactory's Avatar
MFactory is offline
Old 02-25-2014, 11:38 AM
Tinoo's Avatar
Bump for a reply
Tinoo is offline
Old 03-01-2014, 10:08 AM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 03-04-2014, 09:52 AM
MFactory's Avatar
MFactory is offline
Old 03-05-2014, 09:36 AM
MFactory's Avatar
Hundreds of units in stock in the USA
MFactory is offline
Old 06-21-2014, 09:02 AM
MFactory's Avatar
MFactory is offline
Old 07-14-2014, 12:59 PM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 08-08-2014, 10:53 AM
J.Berta's Avatar
Pm'd
J.Berta is offline
Old 08-13-2014, 08:32 AM
MFactory's Avatar
MFactory is offline
Old 08-15-2014, 05:03 AM
MFactory's Avatar
MFactory is offline
Old 08-21-2014, 10:00 AM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 08-28-2014, 01:23 PM
MFactory's Avatar
MFactory is offline
Old 09-02-2014, 10:33 AM
MFactory's Avatar
MFactory is offline
artifex
11-13-2008 08:28 PM
ityab0y
12-15-2007 10:06 AM
Akira
14
12-12-2002 02:47 AM
onesojourner
05-27-2002 06:22 PM
GSpeedR
06-16-2001 06:53 PM
Quick Reply: MAXIMUM TRACTION AND POWER TO THE GROUND - Guaranteed!
