DOES MINI ME SWAP require stage 1 or 2 clutch our new axles
Old 12-03-2013, 07:43 PM
btwnjo's Avatar
Default DOES MINI ME SWAP require stage 1 or 2 clutch our new axles
if i throw a z6 our y8 head,i think your supposed to use a z6 but anyway on my d15b7 in my eg hatch am i gonna have to use a high performance clutch such add stage 1 or 2 Clutch Master our can i use my stock clutch.Also what about driveshafts will those need to be .but in all reality what tranny does a z6 our y8 have is it realty much more beefy them mine.Anyway anyone Who has done this swap your input would be highly appreciated,,ty.
Old 12-03-2013, 08:10 PM
sir.rexington's Avatar
Default Re: DOES MINI ME SWAP require stage 1 or 2 clutch our new axles
I think all stock will work but getting a better clutch will be beneficial always. You should upgrade axles if you're drag racing especially if u r using slicks.
Old 12-03-2013, 08:25 PM
slowDB7's Avatar
You will be fine with the stock clutch/flywheel but you can upgrade it anyways. Won't really do much
As far as axles go, you won't be making enough power to break the stock ones unless your gonna turbo it. Many of the turbo d series guys just buy the cheap auto zone ones cuz they have a lifetime guarantee.
The trannys are not really beefier. But they have shorter gears which means quicker acceleration
And either head will work . the y8 one will up the compression more then the z6 one
Old 12-19-2013, 06:57 PM
Mad Fab Lab's Avatar
Depends on how you drive it, but under normal conditions the stock clutch will hold the power. If you are racing/launching often building up heat and increasing shock load on the clutch, an aftermarket replacement is a good idea.
Stock axles are fine. Id rather break an axle than a differential any day. Just pre-load properly, and make sure you have good motor mounts. If it comes time to replace the axles, I like the NAPA maxdrive axles as they are a little stronger thank stock and lifetime warranty
z6 or y8 transmission swapped in place of the tranny bolted to your D15 will be a vast improvement. the d15 tranny is such a dog, the d16 trannies really pep up the vehicle.
SiR eF_4door
07-28-2009 08:25 PM
kte324
01-27-2009 05:46 AM
maxspeedhonda
01-31-2005 08:17 PM
TheBlackCrx
03-13-2004 11:32 AM
egracer44
08-09-2003 12:11 PM
Quick Reply: DOES MINI ME SWAP require stage 1 or 2 clutch our new axles
