00 Civic Si - struggles to accelerate when warm
Old 11-11-2013, 07:21 PM
95JDMEG9's Avatar
Default 00 Civic Si - struggles to accelerate when warm
Hey guys, I just purchased a 2000 civic si. The previous owner ran the car on E numerous times and I guessed it would need a fuel pump but haven't got to that yet and wanted to get some opinions.
When I cold start it up, it's fine and as well as idle. When I drive it after warm up and press on the pedal, the car will randomly begin to struggle to accelerate like pressing the gas pedal and the car slows down BUT if I shut the car off and turn it back on, it goes back to being normal and then does it again momentarily. The car has full power and accelerates fine all the way to redline when I get a chance of it running fine before it acts up again. What do you guys think is the problem? ALSO, CEL is on and haven't gotten to get it checked yet.
Things I did so far:
unplug battery for a day
saw oil under cylinder 4 spark plug
Old 11-11-2013, 07:48 PM
ewilliams1990's Avatar
Default Re: 2000 Civic Si issue!
Jump the service connector and check what the CEL is for
Old 11-11-2013, 08:59 PM
DumpedSi's Avatar
First place to start is that CEL.
Old 11-12-2013, 04:38 AM
driguy's Avatar
If it's a 2000, it should be OBDII and will have a OBDII port. Even easier.
Old 11-12-2013, 06:02 AM
B serious's Avatar
Wait...why was the car run on ethanol? What's done to it?
Old 11-12-2013, 07:08 AM
BrianB16A2's Avatar
Chances are the CEL is on due to using regular gas maybe. If the previous owner was using cheap regular gas that could be it. Your gonna have to change the o2 sensor and use premium. Not sure till u get the codes tho
Old 11-12-2013, 07:09 AM
95JDMEG9's Avatar
E= Empty fuel, sorry for the confusion.
Old 11-12-2013, 07:10 AM
95JDMEG9's Avatar
Alright appreciate it guys, going to diagnose it today and see what's up. Do you guys think unplugging the o2 sensor and running to car to see if that could be a cause?
Old 11-12-2013, 07:15 AM
ss_zoidberg's Avatar
Check the code first man
Old 11-12-2013, 07:20 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Check the code
Old 11-12-2013, 07:21 AM
doctorake's Avatar
I have no clue how you came to this conclusion.
Old 11-12-2013, 07:27 AM
purgat0ry's Avatar
Dude, hes got a b16, hes a god among men, bow down!
no serious, check the code.
Old 11-12-2013, 09:10 AM
95JDMEG9's Avatar
lol ^
Old 11-12-2013, 09:13 AM
95JDMEG9's Avatar
Alrighty, something somehow told me to check the o2 sensor before getting it scanned and guess what, a (white) wire from the o2 sensor on the header was cut in two. I put that bitch back together and taped it up and BAM problem solved!!!
Once again, I appreciate all of the feedback guys, that's why this is the number 1 Honda forum!
Old 11-12-2013, 11:08 AM
B serious's Avatar
Default Re: 00 Civic Si - struggles to accelerate when warm
Did you solder that wire? Or crimp it? Or just tape it? Just taped it, didn't you?
Old 11-12-2013, 01:36 PM
95JDMEG9's Avatar
Soldered
Old 11-12-2013, 07:02 PM
B serious's Avatar
Nice! Soldering stainless steel sucks, doesn't it?
Tzarinque
09-22-2016 11:40 AM
jakec6
06-12-2013 06:07 PM
Handyman_1
06-02-2009 09:23 AM
paowa
18
04-20-2009 09:02 PM
Egorbopol
02-16-2009 10:26 PM
Quick Reply: 00 Civic Si - struggles to accelerate when warm
