I thought I fixed the problem! Clutch problems
Old 11-01-2013, 09:56 PM
DingDang's Avatar
Default I thought I fixed the problem! Clutch problems
So my clutch is acting a bit weird. It would feel
good, like a clutch should, like it felt when i picked it up after it was changed. However, in the past month or so, sometimes when driving the engagement point changes to all the way back. it engages in the first small movement of the pedal and the last 80% of travel has absolutely no feel/feedback. it only changes to this point, and does so seemingly instantaneously; will change to that and back ten minutes later once every week or so, sometimes will stay like that all day.
I bought a stage 1.5 clutch and a new flywheel
Did a master/slave cylinder less than 7k miles ago. Bleed the clutch lines. It felt good for about a day but went back to its normal ways...
Eg_Hatch92
Transmission & Drivetrain
12-11-2014 09:43 PM
mint95gsr
10-10-2013 01:17 PM
thundernoodle
06-16-2012 10:57 PM
sleepycivichb
08-30-2005 08:57 AM
Quick Reply: I thought I fixed the problem! Clutch problems
