GSR swap obd1 code4
Old 09-28-2013, 07:19 PM
cyoungk's Avatar
Default GSR swap obd1 code4
Hi
I have ek hatch with 98 gsr swap and it throw a cell light
code 4
Everything seems fine but I can't rev up more than 5k rpm
It will shake so I have to rev down, then no shake
friend of mine said replace the dizzy will fix
Is that true?
Old 09-28-2013, 10:57 PM
motoxxxman's Avatar
Default Re: GSR swap obd1 code4
try using the search function. look up what code 4 stands for. that will answer your question.
p.s. the crank position sensor is located inside the distributor.
2ndteg2turn9sec
05-18-2012 02:16 PM
Tensa_Zangetsu
02-28-2009 05:12 PM
crex23
12
08-17-2005 03:24 PM
Quick Reply: GSR swap obd1 code4
