clutch problems
Old 09-26-2013, 09:43 AM
Steven Gilner's Avatar
Default clutch problems
i have a 92 accord with a hydraulic clutch and when i press the pedal to the floor my car still wont start, why? and can i adjust this problem or can i bypass the need to push in the clutch to start my car?
Old 09-26-2013, 12:59 PM
djkurious's Avatar
Default Re: clutch problems
Yes, unplug the clutch switch and stick a paper clip in it. Or if you want to correct the issue, your plastic gourmet probably has fallen apart on the floor mat. Go and purchase this from O'reilly's: Dorman piece (74015)
Old 09-26-2013, 02:52 PM
Mishako129's Avatar
There's a rubber or plastic stopper on the clutch pedal assembly for the NSS (neutral safety switch). The NSS is a switch that engages everytime you press in the clutch. If the rubber stopper is missing then it will not engage the NSS.
The NSS is part 15 in this diagram and the rubber stopper is part 20.
You should be able to see or feel if the stopper is still there. Remember that there are two stoppers on the clutch pedal.
Old 09-26-2013, 10:20 PM
holmesnmanny's Avatar
I didn't even know they carried that piece. Thanks for the heads up!
96H4TCH
06-22-2009 11:19 AM
zc89hatch
02-02-2008 09:05 AM
Nataku
10-19-2007 11:39 AM
TEGPOWER44
12-16-2002 10:11 AM
3rdGteg
11-14-2002 07:43 PM
Quick Reply: clutch problems
