Pop, Clank, sound from catalytic converter region
Old 10-25-2002, 02:23 PM
RAB
RAB's Avatar
Default Pop, Clank, sound from catalytic converter region
I'm post this for my bro (Dr. RAB01GSR) he's at work.
Cliffnotes:
Just recently it snowed in colorado, so it got cold down to 25 degrees. He has 01 GSR (obviously) He also installed a full Comptech I/H/E on his car about 3 weeks ago.
Now last night he heard a clank sound that you normally hear after you turn off your car, usually its somewhat quite and comes from exhaust components. However, last we both heard what sounded like that clanking sound except it was loud, about 10x louder than usually. And he just called me from his work and said he heard the "clank" while he was driving.
Any thoughts.
My silly guess
has to do something with the spring loaded bolts.
Old 10-25-2002, 06:44 PM
Mr.Rab's Avatar
Default Re: Pop, Clank, sound from catalytic converter region (RY8127)
ttt, Or did we answer our own question.
Old 10-25-2002, 06:47 PM
The_Oz's Avatar
Default Re: Pop, Clank, sound from catalytic converter region (Dr. RAB01GSR)
Are you guys certain that it is coming from the CAT area? Definitely check the bolts of course. Other than that, check to see how much clearance does the exhaust have against the heat shield, and check the rubber hangers. I'm no expert, but these are things I would check first.
Good luck,
Oz
Old 10-25-2002, 06:55 PM
Mr.Rab's Avatar
Default Re: Pop, Clank, sound from catalytic converter region (The_Oz)
We haven't check all that ****, because it's cold as ****. But tomorrow I'm going to go take a drive get everything hot and tighten the bolts all around.
gcri11
08-01-2018 08:31 AM
unknown420
06-21-2010 09:28 PM
!xobile
11-06-2005 09:25 AM
Nizzy
Welding / Fabrication
08-16-2004 11:55 PM
redGSRguy
03-25-2002 02:49 PM
Quick Reply: Pop, Clank, sound from catalytic converter region
