question on kill switch
Old 07-23-2013, 11:34 PM
89ED's Avatar
Default question on kill switch
my battery is not a good one. it will not crank over the cold/thicker oil in the mourning. during the day its good. so every night i disconnect the negative terminal. ive done this for some time now. i have even gone as far as installing a "quick release" product for the negative terminal. i do not yet have the budget for a new battery.
my question is if i install a in car kill switch. can i not have to pop the hood and disconnect the negative terminal->anymore?
Old 07-23-2013, 11:52 PM
YellowBacteria1's Avatar
Default Re: question on kill switch
yes. that is the point of said switch.
make sure you get a switch that can handle the current, and thick wiring.
and do it on the negative side only.
if you put a kill switch on the positive side, the wiring will melt, I know I've done it when I was car retarded.
Old 07-24-2013, 02:45 AM
Tim512001's Avatar
I think your real problem is a drain on the battery....unhooking it does what exactly to help it crank a cold car? It stops whatever is draining it all night from sucking power and therefore making your car crank normally. I'd look into what's draining your battery.
Posted from Honda-tech.com App for Android
Old 07-24-2013, 06:45 AM
89ED's Avatar
its the alarm system and the clock that are draining the battery. they are not big enough to drain a battery most would say but they are draining a battery that is weak and needs to be replaced. in the event i forget to disconnect the negative terminal. the next mourning the car will crank but will not turn over.
thanks for your help. also what gauge wire do you recommend i use?
Old 07-24-2013, 08:07 AM
EFlovin''s Avatar
Is your alternator working? Test it.
Old 07-24-2013, 09:09 AM
89ED's Avatar
yes it does. mid day after some driving. the voltage will be at 12.6v
Old 07-24-2013, 09:59 AM
dude the voltage should be 14.5 when the car is on.
Old 07-24-2013, 03:17 PM
EFlovin''s Avatar
Yep, it should be between 14.3-14.4. Yours is wayyyy off.
Old 07-24-2013, 05:57 PM
89ED's Avatar
i meant that. 12.6 off / 13.8 on
the battery should be 13.5- 14.5 when on. your wrong im right about this
Old 07-25-2013, 07:43 PM
zrickety's Avatar
Park on a hill and pop the clutch. The time you spend on all these switches you could do an odd job and buy the battery.
Old 07-26-2013, 08:30 AM
89ED's Avatar
no hills if i were to buy a new battery i would stillend up installing a kill switch. so its inevidable. its just more feesable as of now.
so what gauge wire do i use?
Old 07-26-2013, 08:19 PM
91turbosohc's Avatar
look in the faq section
Old 07-28-2013, 09:29 PM
turn&burn89's Avatar
to answer your question, 8G man. 10G could do it too i guess. why not fixing the existing problem, though, instead of putting on a ''band-aid'' fix?
siblues
Audio / Security / Video
01-04-2011 10:30 AM
civeek
03-05-2006 09:48 AM
granracing
12-11-2005 05:23 AM
flip1199
06-19-2004 12:13 PM
Quick Reply: question on kill switch
