1996 d16y7 mini me y8 swap
Old 07-09-2013, 07:48 PM
sugg578's Avatar
Default 1996 d16y7 mini me y8 swap
So I just finished my buddys d16y7 mini me swap with a y8 head, everything is hooked up and all that junk but we have a surging idle and when yu hit the throttle it drops rpms and you dont speed up. The motor dont die but it drops down in rpms. i have been looking into this on the interweb for the last 3 hours and havent found anything, but i know you all are gonna say use google, when i did and couldnt find anything. Any one have any ideas on what could cause this.
Old 07-09-2013, 08:05 PM
cbaber's Avatar
Default Re: 1996 d16y7 mini me y8 swap
Check timing?
What ECU?
Any CEL's?
Triple check all sensors are hooked up. Map, o2, etc.
Old 07-09-2013, 08:23 PM
sugg578's Avatar
I timing is almost dead on by what we seen still running the y7 ecu and the check engine light is burnt out and i was thinking it maybe the map or one of them just wanted to see what some one else said
Old 07-10-2013, 06:35 AM
cbaber's Avatar
Well what do you expect still running the Y7 ECU? It wasn't programmed to run the VTEC head. You gain nothing from the VTEC head without engine management that can operate it.
Old 07-10-2013, 06:44 AM
kyden's Avatar
well you can't run a 2 wire iac with a 3 wire ecu. get the correct ecu.
kmcvey1989
04-28-2013 06:32 PM
greenman94
10
02-23-2013 03:04 PM
roryss024
12-02-2012 04:36 PM
elmalouno
05-31-2011 08:52 PM
96 EX
01-25-2006 11:00 AM
Quick Reply: 1996 d16y7 mini me y8 swap
