B16 wasting alot of gas!!!!
Old 06-09-2013, 05:42 PM
ef9machine's Avatar
Default B16 wasting alot of gas!!!!
I have a b16a2 amd its wasting alot of gas i did a compression test amd read 175 across the board any ideas?
Old 06-09-2013, 09:13 PM
Crxcam's Avatar
Default Re: B16 wasting alot of gas!!!!
did u just do this swap? Did u use the emmisions canister stuff? have u got ur car in the air with it running to see if its leaking from anywhere? And also how much gas is a lot of gas?
Old 06-09-2013, 10:39 PM
mikekh10a's Avatar
do you have any CELs on?
Old 06-10-2013, 01:51 PM
slowcivic2k's Avatar
Put your right foot in a lathe and take a couple pounds off of it.
Need more information to be of any help
Old 06-10-2013, 02:05 PM
th3pwn3r's Avatar
What transmission are you running?
Old 06-10-2013, 03:48 PM
ef9machine's Avatar
Nah i did it about a year ago! Yes i have the canister and no and its getting about 200 miles to a tank
ef9machine's Avatar
No cels
Old 06-10-2013, 03:49 PM
ef9machine's Avatar
B16 transmission
Old 06-10-2013, 04:06 PM
th3pwn3r's Avatar
Originally Posted by ef9machine
B16 transmission
Well you're getting the same mileage I was getting when I was running a B16 transmission. About 20mpg using a B16 engine/trans on 205/45/R15s.
Old 06-10-2013, 04:17 PM
JDM95Honda's Avatar
does the car idle rough because cars can run pretty bad before the CEL will come on maybe hard start im thinking possible vaccume leak or leaky injector
Old 06-10-2013, 04:36 PM
th3pwn3r's Avatar
Errr, I was actually running 16s, my bad.
Old 06-10-2013, 05:25 PM
91turbosohc's Avatar
sell me your swap and i'll give you my mini-me (38 mpg on hwy).
Old 06-10-2013, 08:48 PM
ef9machine's Avatar
The car doesnt idle rough but does have some trouble starting up!
509b16
15
01-25-2012 03:50 AM
McFlurry
12-25-2009 12:52 PM
superi0ro1
10-26-2005 07:35 PM
thecorey
03-04-2003 10:04 AM
Quick Reply: B16 wasting alot of gas!!!!
