Best way to degrease a motor
Old 10-23-2002, 12:38 PM
White S2k's Avatar
Default Best way to degrease a motor
My valve seal leaks oil onto the outside of the block
what is the best way to remove this?
Old 10-23-2002, 12:41 PM
Neddy1081's Avatar
Default Re: Best way to degrease a motor (whiterice42019)
go to the auto store and get this stuff called engine bright(engine degreaser), it will clen ur block up nice and everything else under ur hood
White S2k's Avatar
Default Re: Best way to degrease a motor (Neddy1081)
hey thanks
Old 10-23-2002, 01:01 PM
frogsr's Avatar
you should fix the problem first... degreasing will only get the gunk off temporarily--it's gonna come back.
Old 10-23-2002, 01:02 PM
White S2k's Avatar
Default Re: Best way to degrease a motor (frogsr)
yea they putting in new seals when i install my cams and valve train
i have a new head gasket set for it
Old 10-23-2002, 01:04 PM
weakGOODJunKieS.com's Avatar
i think simple green works. and if u use compresswater?
Old 10-23-2002, 01:13 PM
White S2k's Avatar
Default Re: Best way to degrease a motor (importoverdomestic)
what is simple green?
Old 10-23-2002, 01:35 PM
performula's Avatar
It's looks like a Palmolive (same deep green too) container with a Windex head on it.
Old 10-23-2002, 01:59 PM
Steve91's Avatar
Don't use Engine Brite or any other engine degreaser on your car. It will discolor aluminum components and is very hard on the paint and rubber in your engine bay. Go to the grocery store and buy Simple Green. You can also get it at the autoparts store. It works wonders. Just spray like crazy, let it sit for 10 minutes and then hose down.
lancerkid06
03-11-2010 04:36 PM
freezerburnv2
12-29-2006 06:20 PM
Jay.D.Em!
03-27-2006 07:47 AM
AndyD
06-07-2003 04:50 PM
xXx Justin xXx
14
05-21-2002 10:24 AM
Quick Reply: Best way to degrease a motor
