Transmission fluid for KAAZ Clutch type LSD
Old 05-07-2013, 01:53 AM
YATCHI's Avatar
Default Transmission fluid for KAAZ Clutch type LSD
I have put a KAAZ clutch type LSD in my 93 DC2 GSR..
Last time i use Redline 75W90 NS manul transmission fluid and go for trackday.
Chatter noise are very large and after 3 section, i found the gear shifting is very bad...
After this i replace them to Valvoline Syn Power fully synthetic fluid. The Chatter noise are reduce. But is it suitable for this LSD??
Any fluid suggestion for this LSD if i keep going for trackday with this? Thank You.
Old 05-08-2013, 01:20 PM
angryhillbilly's Avatar
Default Re: Transmission fluid for KAAZ Clutch type LSD
why not use KAAZ fluid? and maby a friction modifier is you really need.
Old 05-09-2013, 08:17 AM
YATCHI's Avatar
i want to see is there any alternative apart from KAAZ one. KAAZ fluid is a bit expensive here.
What's the use of friction modifier? Haven't heard people using this here. Is that only to reduce the chatter noise or can also reduce the friction of the clutch plate? THX
Old 05-09-2013, 12:08 PM
personally i use valvoline 80W-90 gear oil with a friction modifier. it works great as a alternative to KAAZ fluid in my ATS 1.5 way clutch type lsd. both are typically available at local autoparts store.
the friction modifier helps the diff not to clunk so much. i have seen drastic improvements by using it for daily driving on a clutch type lsd.
http://shop.advanceautoparts.com/web...hTerm=positrac
http://shop.advanceautoparts.com/web...hTerm=gear+oil
Old 05-10-2013, 05:20 PM
YATCHI's Avatar
Thanks, how long will u change the gear oil with the ats lsd??
Old 05-11-2013, 02:39 AM
Np, with how cheap the fluid is, I dont see a problem changing it out every spring. That's my plan. Beem running it less than a year now but can let u know how it performs my track weekend labor day weekend.
DelSol-B18
04-18-2013 08:26 AM
6Spd_EJ6
12-12-2007 09:42 PM
SFWDcoupe
05-19-2006 11:06 AM
SimbaDogg
03-16-2004 07:08 PM
Gump
02-28-2002 04:44 AM
Quick Reply: Transmission fluid for KAAZ Clutch type LSD
