Car Shuts Off after Driving
Okay, I have a 91 Honda Civic Base Model (4 Speed) d15 B1 And I've only had it for a couple months and it never really have me any problems until I was driving and it shut off. And wouldn't turn on I replaced the Starter, Now turns on but when I back out it shuts off, I replaced the Distributer, Sparks Plugs, Throttle & Position Sensor. No check Engine light, Or anything blinking on the dash, ECU Code 7 said to change the Throttle Sensor so I did, But it does the same thing only now, it doesn't blink at all. The car shuts off only when I step in the gas in gear trying to, Car can run idling for as long as I want, Had the transmission checked out and still nothing, And suggestions ?
Re: Car Shuts Off after Driving
its either your computer or main relay, had the same problem with mine and went through hell tryin to figure out the problem except with me first it was the computer then i had to resolder my relay then my fuel pump went bad on a test drive, cant complain for a crx for 200 bucks though and only spent about 150 fixing it
irev210
06-11-2003 07:00 PM
