my check engine codes, need help
Old 04-10-2013, 09:17 AM
jaygood2go's Avatar
Icon2 my check engine codes, need help
Secondary H0S12 (heated oxygen sensor - bank 1 sensor 2) circuit low voltage
Probable cause
Poor electrical connection
Air leak near H02S (bank 1 sensor 2)
Lean A/F ratio
Faulty H02S12 (bank 1 sensor 2)
Please explain in detail and what do i have to do to fix this problem?
Old 04-10-2013, 10:52 AM
GhostAccord's Avatar
Default Re: my check engine codes, need help
There is an issue with your SHO2S, aka Secondary Heated Oxygen Sensor. It is located under the car next to the catalytic converter.
Check the electrical connection to the secondary O2 sensor. Make sure it is clean and tight.
If you have an exhaust leak in front of your secondary O2 sensor, fix the leak.
If you just recently replaced your catalytic converter with a cheap high flow or test pipe... this is a normal code and there is really not much you can do besides try and hack the signal or use a spark plug defouler.
Old 04-11-2013, 04:37 PM
jaygood2go's Avatar
im ordering a new exhaust kit. but im going to check to see if its tight and clean
Teman62
06-29-2019 09:27 PM
papi123
Honda Civic (2001 - 2005)
04-25-2014 09:07 PM
DC4RS Integra
02-12-2008 09:28 AM
Zimmerman
08-05-2006 12:17 PM
Vinhtran17
01-20-2004 04:26 AM
Quick Reply: my check engine codes, need help
