99 Civic 3 wire to 2 wire idle control valve help
Old 03-28-2013, 10:36 PM
xKING239x's Avatar
Default 99 Civic 3 wire to 2 wire idle control valve help
just hooked up my performer x manifold up with the 2 wire idle control valve. picked up the connector from the junk yard, i should be able to wire it up and leave the orange wire disconnected ?, or do i have to move pins around ? just finished putting the motor back in the car and trying to get it to idle right, anyone know anything?
Old 03-29-2013, 05:26 AM
kyden's Avatar
Default Re: 99 Civic 3 wire to 2 wire idle control valve help
you have to move pins around. but you can't use a 2 wire in place of a 3 wire on the same ecu.
Old 03-29-2013, 10:03 AM
xKING239x's Avatar
[QUOTdokyden;48621391]you have to move pins around. but you can't use a 2 wire in place of a 3 wire on the same ecu.[/QUOTE]
What do you mean? The Edelbrock mani is made door a 2 wire. So I'm not going to be able to use it without changing the computer?
jvr
04-11-2014 11:56 PM
boricuacivic
04-06-2009 09:02 AM
antivic
07-21-2008 05:27 PM
Quick Reply: 99 Civic 3 wire to 2 wire idle control valve help
