brake lights dont light up when i brake
Old 03-24-2013, 09:37 PM
TomCurllyFry's Avatar
Default brake lights dont light up when i brake
whats up guys so i just noticed this last night and its really bugging the crapt outta me, so i noticed when i brake the secondary brake lights dont illuminate, any help would be gratefull at first i thought both bulbs we bad but when i turn my light switch on everything lights up but even the primary's brake lights its when i press the brake nothing happen i checked for ripped wires and fuses but all looks good my last guess is the brake switch above the pedal any help?
Old 03-24-2013, 09:40 PM
95h22sol's Avatar
Default Re: brake lights dont light up when i brake
I would assume the brake switch as well. Not very expensive if I am correct. You should be able to get it at any automotive store.
Old 03-24-2013, 09:52 PM
hOnda_hiEn's Avatar
did you check the bulbs? they are a dual filament. brake filament can be bad. as the running light is good. fuse?
Old 03-25-2013, 12:03 AM
Filliments were both intact they are dual filliment and yea I'm gonna have to do that then when I get paid any idea on why the switch would go bad? Obvious answer is its old lol but anything that could really cause it
Old 03-25-2013, 12:24 AM
renzis00's Avatar
bad connectors? check for loose connectors, corrosions, bent/broken terminals. check if its getting voltage with a multimeter.
Old 03-25-2013, 09:29 PM
ima check tommorow hopefully its just the switch
eTiLiKo
08-09-2018 03:03 PM
phrenzykEG6
04-12-2010 08:54 AM
musclehead954
02-27-2008 10:28 AM
Project JDM CRX
02-07-2007 05:00 PM
hAtChXcElR8tion
05-17-2004 07:06 PM
Quick Reply: brake lights dont light up when i brake
