Place your bets.
Old 11-04-2013, 02:44 PM
  #26
Ridin Dirty in Cali
dirty19's Avatar
Default Re: Place your bets.
Guess i need to login to NASA every now and then?
Old 11-07-2013, 09:26 AM
  #27
1998GsRIntegra's Avatar
Glad your hard work was finally rewarded with a reliable engine.
Old 04-07-2014, 06:30 PM
  #28
Lo-Buck EF's Avatar
this was almost bad. caught it in the pre-season checks. we went back to oem retainers.
Old 04-08-2014, 03:36 AM
  #29
VTECIntegra9's Avatar
Moar pix! Is that wear or deformation? Hard to tell in that top view.
Old 04-08-2014, 06:52 AM
  #30
Lo-Buck EF's Avatar
Wear. The spring does move around especially at high revs.
Old 04-09-2014, 12:52 PM
  #31
known's Avatar
B Crower makes some steel retainers too just FYI. Awesome to see you have such a good season, and are still running!
Old 04-09-2014, 09:57 PM
  #32
Runnerdown's Avatar
What is that supertech springs and retainers?
Old 04-11-2014, 03:57 PM
  #33
coolhandluke's Avatar
Yikes, close call.
Old 04-16-2014, 05:47 AM
  #34
Lo-Buck EF's Avatar
Yup. First time I've had them wear this fast. But my other engines were 1.8s that revved almost 1000 rpm less.
Still runs. Won the first race of the season, was leading the second race and got pushed off my an out of class car and retired with damage.
Old 04-16-2014, 04:49 PM
  #35
Runnerdown's Avatar
I'd treat that pretty seriously. Rapid wear like that is a sign of an unhappy valvetrain. Do you know what spring kit it is from supertech? And what cams does it have. If those retainers wore that quick an oem one may snap. Unless it was a material defect. I'd look a little deeper into root cause on that one...
Old 04-28-2014, 05:41 AM
  #36
1tuffbb6's Avatar
Subscribed.
Old 04-29-2014, 03:04 PM
  #37
Lo-Buck EF's Avatar
its the supertech kit for oem cams. i have the pn downstairs.
the head has oem '00 itr cams in it. a few old school b series guys confirmed that it happens with ti retainers at high revs. the springs move and wear the retainer. i can see the evidence of the spring moving on the bottom of the retainer.
Old 04-29-2014, 05:31 PM
  #38
Calif_Kid's Avatar
Any idea how high the revs have to be to have this occur with the Ti retainers? Or if the revs are lower, will the problem still occur, but just take longer to show up? I've got a JDM type R, and I usually shift around 8200rpm,but the rev limiter is at 8500rpm, so just wondering about this issue. Is the issue just confined to the Ti retainers? - Jim
Old 04-29-2014, 06:45 PM
  #39
Lo-Buck EF's Avatar
I have a couple heads with the same retainers. The gsr only spun to 8500 and the retainers lasted at least 25% longer. A general rule of thumb is to check ti retainers once a year at a minimum.
Or just use steel oem ones. 3 days and some dyno pulls on them. No issues.
Thanks chad for the tip.
Old 04-30-2014, 03:55 AM
  #40
American.Graffiti's Avatar
Glad to see this thing is holding together.
Old 01-01-2015, 03:30 PM
  #41
Lo-Buck EF's Avatar
still runs
Old 01-02-2015, 01:19 PM
  #42
rice_classic's Avatar
I thought this oldie but goodie was appropriate:
Old 01-26-2015, 03:16 PM
  #43
still runs
Was I right or was I right?
besherse
03-01-2016 11:56 AM
jaysome01
04-05-2009 10:43 PM
jaysome01
04-03-2008 03:55 PM
jdm_sir2
02-02-2007 06:04 PM
TnLude2000
02-23-2005 06:16 PM
Quick Reply: Place your bets.
