only brake light work nothing else HELP!
Old 02-09-2013, 08:22 PM
hondacivicEH93's Avatar
Default only brake light work nothing else HELP!
Only my break lights work in the rear of my 93 eh hatch. NO parking NO Reverse and no turning signals work in rear. Radio and climate control dont light up either. Now both headlights work, parking lights in front work and turning signals work in front. Cluster lights work. All good fuses and bulbs. Please help!! And my seatbelt light stays on when car is off. And goes out when you turn key on
Old 02-15-2013, 03:23 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
Default Re: only brake light work nothing else HELP!
I think theres an interior fuse under the hood fuse box, did you check those also? If thats good too, you can check the wires, take a test light to the power wire and see if you get power.. i think it may be a ground issue...did this always happen?
Old 02-15-2013, 08:38 AM
harleyrobert1's Avatar
Try ground wires.
Old 02-15-2013, 01:28 PM
Former User's Avatar
You need to mention what car you have. You also need to check for blown fuses.
Old 02-15-2013, 01:29 PM
Originally Posted by harleyrobert1
Try ground wires.
The taillights, turn signals, and brakes share a common ground, so that's not likely the problem.
aznology
01-23-2010 09:54 AM
215ek
04-06-2009 08:10 AM
tearinox
10-19-2006 06:49 PM
im done
11-12-2004 08:52 PM
Bserieskllr
12
08-01-2004 01:38 PM
Quick Reply: only brake light work nothing else HELP!
