Any fogged window tips tricks or product?
Old 12-04-2012, 07:09 AM
Andycuso's Avatar
Default Any fogged window tips tricks or product?
I have a Crx 88 and iv had the motor swapped. I have no ac or hot air and my windows r always fogged in the morning and at night. Any one have any tips trick products that works for them. I no there anti fog spray but I don't want to buy some random spray with out seeing what other Hondas use.
Old 12-04-2012, 08:04 AM
Moderator
snobordboy's Avatar
Default Re: Any fogged window tips tricks or product?
Get your defrost working with heat, make sure you have the vent set to fresh air, not recirculate. If you can, park with the windows open overnight inside a dry place.
Recently I heard about using a product meant to keep boats and rvs dry while stored, just put some of these little ***** of absorbant into a plastic container with holes in the lid, and replace as often as neededwhen they absorb moisture.
Old 12-04-2012, 08:41 AM
Fnix's Avatar
U can use damp rid
Old 12-04-2012, 09:45 AM
Andycuso's Avatar
I heard that a white vinegar water solution works. Any body try that?
I also was thinking of buying a ac/dc converter and buying a small heater but I'm worried that I won't be able to get enuf power out of it to turn the heater on
Old 12-04-2012, 10:04 AM
4cylfiend's Avatar
You can cut a Potato in half and rub it all over the windows. That is one simple way to do it, as weird as it sounds..
dpkelly
Honda Civic (2006 - 2015)
12-10-2013 09:34 PM
DAVE15401
17
01-16-2006 04:11 PM
Rocks
12
01-05-2005 01:28 PM
E dwinbon G
24
03-02-2004 12:13 AM
Driven
13
01-21-2004 12:27 PM
Quick Reply: Any fogged window tips tricks or product?
