90 sedan/b18a swap - pass radius rod is right on my tranny
Old 11-24-2012, 04:46 PM
maineef's Avatar
Default 90 sedan/b18a swap - pass radius rod is right on my tranny
i have a 90 sedan wtih a b18a and my pass radius rod is right on my tranny when i slam my car down only way it doesnt hit is if im up about 2inches from bottom on my tiens. My question is do they make an aftermarket radius rod for the b series application or am i stuck fabricating one
Old 11-24-2012, 05:00 PM
tonylovesjdmEF9's Avatar
Default Re: someone must know the answer
Ummm you are having issues with your mounts bro
Old 11-25-2012, 08:10 AM
RTFM
v4lu3s's Avatar
if your mounts are good then maybe you should not be dropping the ride height ALL the way down...if you have to do that for some unknown reason then you probably will have to fabricate it.
b20vtech
11-07-2008 04:37 PM
DC_RaceR
06-29-2007 01:25 AM
cornbread
12-02-2002 10:03 AM
civtegman
05-24-2002 01:14 AM
Quick Reply: 90 sedan/b18a swap - pass radius rod is right on my tranny
