which intake mani gasket should I use?
Old 11-13-2012, 06:50 PM
Cheefer_EX's Avatar
Default which intake mani gasket should I use?
I have a Z6 head with a y8 intake manifold and I need to know which intake gasket to use. Right now, I have a OEM y8 gasket on there torqued to 17ft/lbs. as per spec. The car has developed an idle issue and a smoke machine and carb cleaner have confirmed this. I didn't use any RTV or "monkey snot" as my mechanic calls the stuff (some black 3M gooey sealant). I know the gaskets look different but I'm not sure if the gasket should match the head or vice versa. Any ideas or suggestions? Should I use any gasket sealant?
Old 11-14-2012, 08:11 AM
strategy400's Avatar
Default Re: which intake mani gasket should I use?
I always use some of the permatex brown aviation sealer (shellac) on the manifold side of the gasket.
Buy a Z6 and Y8 gasket and compare...
Old 11-14-2012, 11:05 AM
Cheefer_EX's Avatar
I sparyed carb cleaner between manifold and cylinder head and the car bogs down. That would signal a vacuum leak, no?
I looked at the TMs for both manifold gaskets, they look quite different...
Old 11-15-2012, 11:03 AM
97_ek_coupe's Avatar
Yep, you have a leak. I had the same issue with my mini me swap, all you have to do is seal it up. I removed my mani and put silicone and it took care of the vacuum leak. Good luck
Old 11-15-2012, 11:11 AM
10psiLsEf2's Avatar
d16 z6 gasket.
You do not need to put any snot,seal,silicone,monkey glue,super glue on intake manifold gaskets buddy.
And why are you using the y8 manifold?
Old 11-15-2012, 11:48 AM
kaiba's Avatar
Y8 has the best flow for OEM manifold D-series. If I were the OP, I use thermal gasket like Hondata/Blox. It's little more expensive but it's completely reusable.
Old 11-16-2012, 04:22 AM
Cheefer_EX's Avatar
It's what I have available. z6 head and y8 block. It's my daily driver for now.
I'm buying a z6 gasket this time around. I heard you aren't supposed to use the sealant unless the manifold is warped bad.
Old 11-17-2012, 04:28 PM
Cheefer_EX's Avatar
I went with a z6 felpro gasket from Autozone. It doesn't create a complete seal so I used some RTV to finish the job off. It's purring like a p*ssy now.
AllmotorGSReg
20
04-12-2013 05:57 PM
eg2phosizzle
02-23-2006 09:02 PM
mr. carpenter
04-20-2005 07:28 PM
Quick Reply: which intake mani gasket should I use?
