B series with K series axles and K series cv joints?
Old 10-18-2012, 06:57 PM
Moderator
crazes's Avatar
Default B series with K series axles and K series cv joints?
This is pretty much a copy of another thread. I have a few that would like more information about this so i figured put it in here and see if there is some more info over here for them
Ok I know I've read it somewhere on Honda-tech that people been running there b series swapped cars with k series Axle's to be able to have the stronger 36mm outer cv joint... For the life of me I can not find any more info on what has to be done to do this, which axles are used and what mod's have to he done to do so ... So if anyone has any info on it is like to know
And if anyone is having good luck with this set up Thank!
Some actual part numbers would be great also
Old 10-18-2012, 07:24 PM
hondab18b67's Avatar
Default Re: B series with K series axles and K series cv joints?
i hear b series inners, shafts and rsx type s, accord,or prelude outers with karcepts spindles
Old 10-19-2012, 12:26 AM
hybridpatient95's Avatar
almost 100% sure K series inners fit in b series trans no need to swapp inners
just need the karcepts hubs
Old 10-19-2012, 04:19 AM
061000rr's Avatar
i ran 90-91 prelude si hubs. you use the inner race's of the prelude wheel bearing and the rest of the integra bearing. you can then run accord outters with the big shaft b series inner's and shafts. and you can keep 4x100 4 lug wheels.
Old 10-19-2012, 04:58 AM
Mo_Spec's Avatar
I'm using stock 06 civic si axles in a b series eg no modification to axles. Just karcepts hubs.
Old 10-19-2012, 06:54 AM
eg_bseries's Avatar
This is what I have been looking for. Thanks man.
Old 10-19-2012, 08:44 AM
hella vtec yo's Avatar
just get crv axle or integra type r axles . bsries axle length and has 36 mm outer
Old 10-19-2012, 08:52 AM
no need for carcepts hub get 90-91 prelude hubs from your local autozone or parts store
Old 10-19-2012, 10:30 AM
only jdm integra type r is 36mm
cant buy that at autozone
Old 10-19-2012, 11:08 AM
dschenke's Avatar
running pro drive hubs
Old 10-19-2012, 11:50 AM
Sickteg24's Avatar
has anyone proven that they're actually stronger or more durable?
Old 10-19-2012, 12:03 PM
meane30's Avatar
We've been running them in our car for 3 years now and broken one axle
Old 10-19-2012, 12:15 PM
surfingsk8r's Avatar
By "in our car' are you referring to the one in the sig line 9.19 at 16x mph. If so that's rather impressive.
Old 10-19-2012, 12:45 PM
Jdmrange's Avatar
bumppppppppppp
Old 10-19-2012, 05:02 PM
theidealone's Avatar
Yea. Mo_Spec and meane30 built and race the PFC hatch. That is PFC right there.
Old 10-19-2012, 09:44 PM
93ls10.0's Avatar
Any certain one to run in a da? Different lengths?
Old 10-20-2012, 12:08 AM
DA uses longer axles correct? if so get crv 97-01 36mm axles
Old 10-20-2012, 07:30 AM
93ls10.0's Avatar
Sweet. So other question if u do the 90-91 prelude hubs u have to get both sets of wheel bearings do make one set work?
Old 10-21-2012, 09:53 AM
061000rr's Avatar
I got mine used with tho hole spindle. And just used my old integra bearings and the inner race's that were on the hubs. There is a used Honda parts place on eBay that has several sets of spindles. They have the stock axles also. You may be able to run the prelude axles and not have to make your own.
Old 10-21-2012, 10:39 AM
Mo_Spec's Avatar
Just a heads up for those doing this, the oem Honda/Acura axles use larger shafts and stronger cv's then the autoparts store brands. Basiclly the oem ones are stronger.
Old 10-21-2012, 05:48 PM
DraginX's Avatar
I know this is off topic but simular so I'll ask, is there oem hubs you can use with the dss 5.9 axles?
Old 10-21-2012, 06:08 PM
sweetfwdthunder's Avatar
No, Im pretty sure they're the same outer as a GM 4wd truck. The outers on my 5.9's and the front axles of my truck look identical
Old 10-21-2012, 06:16 PM
K20EF8Dx's Avatar
More info on this other thread please.
Wanting to know more info for my DA Integra, I need to put extended studs in it and would like to look into this alternative for now.
Old 10-21-2012, 06:20 PM
Moderator
crazes's Avatar
its basically the same thread. there was no real information on there. Had a few people ask to me post in here for more knowledge
Old 10-21-2012, 10:16 PM
Hyper16-Johnny's Avatar
I beg to differ, my 2000 ITR had 36mm axles as well as my buddy's 01' ITR! 97' and 98' ITR's might be the 32mm axles.
Quick Reply: B series with K series axles and K series cv joints?
