97 accord ex 2.2 v4 vtech, a/c problems
Old 09-18-2012, 03:35 PM
Nebbyz's Avatar
Default 97 accord ex 2.2 v4 vtech, a/c problems
I have the 97 accord, and my a/c isn't working. When i turn it on it blows air, but it blows hot air. I checked the heater valve, and that's still working. When i turn the a/c on the radiator and a/c condenser fan do not blow, but they do both come on if my car starts to get hot, they also sometimes turn on when the car is off. I'm out of ideas and need some help please.
Old 09-19-2012, 01:53 PM
badcb7's Avatar
Default Re: 97 accord ex 2.2 v4 vtech, a/c problems
you should bring your car to a shop to see if you got a leak in your a/c system and if you dont a recharge wouldnt be a bad idea. also when you press the a/c button does the light turn on? the light indicates the a/c clutch is working.
Old 09-20-2012, 05:03 AM
forted's Avatar
Another thing you can look at is the ac compressor, see if the ac clutch engages when the ac is turned on. If it doesn't engage it is most likely because of low refrigerant.
Old 09-20-2012, 08:15 AM
j13
j13's Avatar
If the fan and compressor clutch doesn't engage, the system is super low on pressure and dead. The high pressure line has a pressure switch. When the pressure gets super low, it will trigger the switch causing the compressor and fan not to spin (I'm guessing to prevent causing alot of damage to the compressor). If you try recharging you'll be wasting it since you might have a horrible leak. If the compressor and fan turned on and you have hot air coming out, than a recharge would most def work.
Possible problems:
Bad relays
Bad switch
Very bad leak in the system
Fuse(s)
Electrical connections
Cut wires
The list can go on. Take it to a nice AC shop and have them look at it.
kikoboy
06-17-2016 09:04 AM
billybobdad
03-02-2013 01:33 AM
SLCAccord
04-20-2007 05:41 PM
jdadams12
07-13-2006 08:05 AM
freddy_hung
11
09-21-2003 07:32 AM
Quick Reply: 97 accord ex 2.2 v4 vtech, a/c problems
