civic starting problems
Old 08-31-2012, 07:58 PM
b20hondacivic's Avatar
Default civic starting problems
hey guys ive recently been running into a few problems starting my civic.
1. Sometimes when i crank the ignition it wont start but simply just click once. It doesnt start after that and i would have to keep cranking it and sometimes it would start.
2. After leaving the car parked for a couple of days the battery gets drained. If i dont start it for a day or 2 the battery would get drained and i would need a boost. Wha might b causing this?
this is a 94 civic btw
Old 08-31-2012, 07:59 PM
jbpnoman's Avatar
Default Re: civic starting problems
Replace the battery. It's run its life and is shot.
Old 08-31-2012, 08:05 PM
this is the second battery ive ran thru. but im bout to get it tested this weekend hopefully its that nn nothing else
Old 08-31-2012, 08:45 PM
Ridin Dirty in Cali
dirty19's Avatar
Check all the engine grounds..... no loose wires
Old 08-31-2012, 09:56 PM
ok ill check all that tomr thanks guys really appreciate it
Old 08-31-2012, 10:03 PM
Ryan Lwin's Avatar
It's your clips. Not the battery. They are not good. Replace the clips.
Old 09-01-2012, 05:05 PM
what do you mean by clips? the terminals?
Old 09-01-2012, 05:15 PM
Ryan Lwin's Avatar
These things. When they are old and rusty and loose, current can't travel through them as well and not enough current will cause your starter to hesitate because not enough power.
Old 09-01-2012, 05:29 PM
redm3turbo's Avatar
I changed out my terminals to something like this
after a similar thing happened to me. I got them at a local hardware store in the fastners isle for like 3 bucks...(if you go to a autoparts store I think they are like 6)
the stock honda ones aren't great. Get something with a dual post bolt....
Id try cleaning what you got already first though....
Old 09-01-2012, 05:32 PM
Former User's Avatar
If the terminals are fine, you may want to test for parasitic drain:
http://batterychargerstore.com/what-...tic-drain.html
Old 09-01-2012, 06:56 PM
oh that might b caus my terminals are mad old nn a lil loose. but that will caus the battery to drain? caus sometimes i would leave the car for a while n the battery would jus die
Old 09-01-2012, 07:00 PM
Ryan Lwin's Avatar
If battery die by itself after a few days, then you also need new battery + terminal clamps/clips.
Old 09-01-2012, 07:02 PM
thanks a lot tho guys i relly appreciate it
Old 09-01-2012, 07:14 PM
JDM-sol 89's Avatar
did the new terminals fix the problem?
Old 09-01-2012, 07:33 PM
uhh where can i find new terminals for a 92 civic?
Old 09-01-2012, 08:08 PM
Ryan Lwin's Avatar
Any auto parts stores man. They are usually near batteries. Or ask them. Terminals are the clamps that are connecting the wires and the battery leads.
Old 09-01-2012, 08:10 PM
oo alright imma go get them tomr . hopefully that fixes these problems lol
Old 09-01-2012, 08:14 PM
Ryan Lwin's Avatar
Are you in U.S? If so, go to Autozone, O'Reily or PepBoys, take your battery with you and ask them to test it. It's free. I think you are gonna need a new battery too since it's losing energy quickly.
Old 09-01-2012, 08:34 PM
yeah i was planning to do that but i got there too late nn i never knew yu can jus switch the clips like that i thought you had to get a whole new wire but imma get that done hopefully that fixes everhting
Old 09-02-2012, 01:41 AM
fragmare's Avatar
Yea, I'm with Ron... take a multimeter and look for a parasitic draw/drain. It's easy and free and it might just solve your problem. While you've got the multimeter out, it would be a good time to test your battery and alternator too.
xander1100
10-18-2009 07:56 PM
92CivicSIRhb
10
05-04-2005 11:44 AM
Propulsion
03-27-2003 04:11 PM
tan2
11-04-2002 10:10 AM
Quick Reply: civic starting problems
