why is there a clunking noise from rear passanger side?
Old 08-14-2012, 12:22 AM
theguy22's Avatar
Default why is there a clunking noise from rear passanger side?
so i just started noticing one day that there was a clunking noise in my rear passenger side suspension. i went and checked underneath but didn't see any worn out things. i notice the clunk when i hit bumps. and now at times i could even hear some kinda weird sound like something is cracking or something. almost the same sound as 2 metals grinding amongst each other, makes a weird pop corn sound sometimes too. well this really scares me and i dont know what it could be. i hear the sound from the trunk kind of. if it helps, everything on my 1997 civic coupe's suspension is stock besides the function and form coilovers and i have a pair of skunk 2 LCAs.
Old 08-14-2012, 12:42 AM
jbpnoman's Avatar
Default Re: why is there a clunking noise from rear passanger side?
Sounds like your strut is blown on that side.
Old 08-14-2012, 01:13 AM
Technical Hero
HondaPartsHero's Avatar
Do you have a rear sway bar?
Old 08-14-2012, 01:24 AM
Tkrizz's Avatar
Does this happen when you hit the brakes as well? Mine has started doing this recently but doesn't when i'm on the brakes. Don't drive the car much so i figured i would figure it out when i do the rear disc swap.
Old 08-14-2012, 11:57 AM
theguy22's Avatar
No. Just over a bump or slope at times. Yeah ima check it this week when I get my rear disk brake swap
Old 08-14-2012, 12:32 PM
98trooper's Avatar
Mine was doing it as well, changed out the coil spring isolators with some new ones from energy suspension and it seems to have helped tremendously. I did front & rear since i was doing it, took about an hour and the parts were like $25 shipped.
http://www.energysuspensionparts.com...%2E6103%5FRear
Old 08-14-2012, 02:21 PM
theguy22's Avatar
I see you said "helped". So it didn't fix it? It just helped?
Old 08-14-2012, 03:57 PM
InTheZoneAC's Avatar
jack the back right so the tire is off the ground. Try to move the tire in all direction, pulling and pushing it.
It's either your trailing arm bushing(not seated evenly anymore), the upper control arm(worn bushings), the lower control arm(worn bushings), your strut or any part of it that could be binding, or rear sway bar mounts if you have one.
Old 08-14-2012, 04:07 PM
Technical Hero
Old 08-15-2012, 10:06 AM
theguy22's Avatar
thanks, will do that on the weekend when i got no work. hopefully its just the trailing arm because im going to have some new ones with new bushings this weekend when i get my disk swap. i don't think its my lower control arms because i put brand new skunk 2 bushings on it like 6 months ago.but then again i hear some pretty bad reviews about skunk 2 LCAs haha thanks. and no I DON'T HAVE SWAY BARS hahaha
Old 08-15-2012, 10:23 AM
ozh_hawaiian's Avatar
I was also gonna say check your trailing arm bushings!
Old 08-15-2012, 11:28 AM
98trooper's Avatar
yeah there still something else going on but all my bushings appear to be ok. when I say helped I mean really helped, well worth the time and $25.
Old 09-30-2012, 09:32 PM
theguy22's Avatar
so i did my rear disk brake swap today. and found that the bushing on the LCA that connects with the disk brake on the side that i heard the noise coming from is torn. part of it is like almost off. so is that most likely the problem? im going to order some bushings tomorow from skunk 2
Old 09-30-2012, 09:52 PM
jayeghatch's Avatar
I have the same problem on my 94 eg, an still have the problem, I change the rear trailing arms an bushing, new shock an lowering spring, new LCA,
An I'm still hearing the same clunk noise.
Old 10-01-2012, 12:02 AM
theguy22's Avatar
you're scaring me.
Old 10-01-2012, 01:14 AM
Technical Hero
Take a pic of it and post it
Old 10-01-2012, 04:45 AM
EGpurp92's Avatar
Does your exhaust run in between the body of the car and the rear passenger LCA?
Old 10-02-2012, 10:52 PM
theguy22's Avatar
i got the stock exhaust. i didnt do no tweaker ****.
Old 10-02-2012, 10:53 PM
theguy22's Avatar
i will. and i will also let you guys know if changing to the stock LCAs took away the noise or not.
Old 10-06-2012, 08:23 PM
theguy22's Avatar
So i changed to stock and i still hear the clunking noise. tightened the bolts of the strut from inside my truck, still there. although i noticed as i had the LCA out, i would push up on the rear disk that i have so that the whole trail arm moves up, i would hear the clunk. i am assuming it must be that. its not the trailing arm. not the LCA, must be on the piece where the alignment is done. i do not have camber kits. anybody have an idea? i will mess with it some more when i get a day off work
Old 10-07-2012, 07:11 PM
theguy22's Avatar
bump
Old 10-07-2012, 08:46 PM
turbocoup97's Avatar
remembering way back to when my civic was bone stock, i was hearing a clunk randomly one day out of nowhere. turns out my factory exhaust had slipped out of the hanger just before the lca and was bouncing on the lca, just a thought. i would def check that out. make sure all the hangers are still attached. also could possibly be an upper strut mount? don't remember seeing if you replaced these or not, reason being you're hearing the clunk when pushing up the assembly without the lca attached. noise diagnosis is rough!
Old 10-08-2012, 09:59 AM
theguy22's Avatar
indeed it is rough. i will check on that again when i get a freakin day off from work. i doubt its my exhaust but i will double check. the noise is so irritating.
Old 10-20-2012, 05:36 AM
By twin's Avatar
I just purchased an 07 for my daughter. I noticed excessive wear on the interior edge of the tires. I changed the shocks trying to correct the wear. Now I have the noise described in this thread. It wasn't there before. Changing the shock a 2nd time did not alleviate the problem. Can anyone help?
Old 10-21-2012, 06:58 PM
theguy22's Avatar
MY problem happened to be a blown shock. your problem sounds like toe out, which will require an alignment to fix. happens when someone lowers their car. do you have after market shocks or after market springs? or coilovers? the shock has nothing to do with that.
Quick Reply: why is there a clunking noise from rear passanger side?
