D16Z6 Valve Guides - What size sleeves/liners do I get?
Old 08-11-2012, 05:19 PM
KHANV1CT's Avatar
Icon2 D16Z6 Valve Guides - What size sleeves/liners do I get?
I've got my D16Z6 head in the machine shop getting it resurfaced and a valve job. I already knew I needed valve guides and seals because the exhaust valves have a TON of play. Anyways, the machinist suggested getting sleeves/liners instead of doing all new guides like I planned because pressing in new guides is risky because of the aluminum head.
Down to the point. What size sleeves/liners do I get? Where can I find them? Or do any of you guys have any other suggestions?
Old 08-11-2012, 10:22 PM
Master Detailer
98civdx's Avatar
Default Re: Question About Valve Guides
He reccomened them, ask his opinon.
Personaly, I would just replace the guides.
Old 08-12-2012, 01:40 AM
KHANV1CT's Avatar
He doesn't really know, he said to just buy them online and he showed me some that were suitable for a V8 Chevrolet. I've found some sleeves I just need to know the size.
Old 08-12-2012, 03:25 AM
fragmare's Avatar
I don't know about sleeves. Replacing the guides seems like the proper fix whereas installing sleeves sounds a bit janky and more like a band-aid fix. Figuring out what kind of guides your car uses should be as simple as looking at the service manual. Hell, you can probably get on O'Reilly's website, search for guides and punch in your car info and the proper intake/exhaust guides should come up.
Old 08-12-2012, 03:51 AM
fragmare's Avatar
Yea, here you go.
http://www.oreillyauto.com/site/c/se...rd=valve+guide
Not sure what year Civic you have, but these are for a 92-95 Civic EX with a D16Z6 engine. Apparently for your D16Z6, unlike my D15B7, the intake and exhaust guides are the same size.
Pressing in new guides shouldn't be a problem for a reputable machine shop, honestly. Many heads are made of aluminum. The manual instructs you to heat the head to 300F and place the guides in the freezer for an hour or so and then just drive them in with a guide driver.
Old 08-12-2012, 02:45 PM
KHANV1CT's Avatar
Default Re: D16Z6 Valve Guides - What size sleeves/liners do I get?
I guess since nobody knows about the liners I'll just take a risk with the guides. The reason why he doesn't want to do it is because theres a high risk of cracking the head or the guides not staying in. *Crosses fingers*
Old 08-12-2012, 02:49 PM
been there done that
doood's Avatar
You should probably find a different shop then
Old 08-12-2012, 02:53 PM
fragmare's Avatar
The riskiest part is getting the old guides out. And it's only really risky if they have to drill them. For an experienced machinist, it really shouldn't be too much trouble, either way.
Old 08-12-2012, 03:21 PM
KHANV1CT's Avatar
Alright, thanks guys. Unfortunately it's the only machine shop in my area with reasonable prices but hopefully he won't eff it up.
Old 08-12-2012, 03:49 PM
Master Detailer
98civdx's Avatar
This. He shouldn't be reccomending things if he doesn't know what he is reccomending.
Old 08-12-2012, 04:34 PM
NotAJDMFanBoy's Avatar
when I got my gsr head rebuilt, I just bought new guides made by Supertech (recommended over kms, different type of bronze), and they put them in. It was my understanding this was a pretty routine job...
Old 08-12-2012, 09:30 PM
KHANV1CT's Avatar
Haha I guess this guy just sucks. Really he's the only one in town.
Old 08-12-2012, 10:04 PM
fragmare's Avatar
He might be perfectly capable... he might just not want to do it for whatever reason, who knows. Laziness? Unwillingness to work on "them Jap imports"? The machine shop down the road happily resurfaced my cylinder head when I did my head gasket, and everybody was really nice and courteous. They are very reputable around here and have great rates. After I picked it up, though, the machinist was heading out and commented something to the effect of "Man, I don't know how you work on those import cars. I couldn't do it". I was thinking to myself, "It's a Honda, it's not rocket science. They're put together in much the same way as any other car." I think what I actually said, though, was "Eh, it's not nearly as tough as you might think."
Anyway, my point is he might be making excuses to not do work he doesn't want to. Sounds like you should find a shop in the next over if that's the only one around. From everything you've said, I wouldn't trust them with my parts...
Old 08-18-2012, 11:10 AM
KHANV1CT's Avatar
Ok so I brought the block up there to have it bored over. It's just bare-*** block, nothing on it, no girdle, no crankshaft, nothing. Well after he noticed it didn't have a girdle he said he needed that to attach it to the honer. Well that's coming off the engine I'm using right now but he spazzed out and said "that's a no no". Is it true that I can't use those parts from the other engine? He said the crankshaft and the bearings are coded to the engine and you can't interchange them because it will tear the engine to pieces. So he wouldn't take the block in and told me to find another one that is complete with a crank and so on. It seems like I've heard of people changing these out between engines before, I dunno.
Old 08-22-2012, 07:42 PM
KHANV1CT's Avatar
BUMP....Are the crankshafts interchangeable without catastrophic results?
Old 08-22-2012, 10:43 PM
jbpnoman's Avatar
Z6 to Z6? They're interchangeable, but you might need a line bore. Check your clearances.
Old 08-23-2012, 04:38 AM
purgat0ry's Avatar
Little do most people know who think along those lines...
These cars are more 'Murrican than they may think, a good hunk of them are co-designed between the R&D facilities based out of Raymond, OH and LA and of course, some over seas in Japan.
The plant in Raymond cranks out TONS of Accords and CR-V's. Most of the Civics are done elsewhere of course... but most of your parts? sourced within the US, I know of four or five separate plants here in OH alone that crank stuff out for Honda, everything from bolts to seats; point is, "Them there jap cars" support our economy more than other companies like Chevy (See: HHR, built in Mexico, IMPORTED to USA)
Old 08-23-2012, 06:16 AM
jbpnoman's Avatar
I got chased out of my Uncle's house after I took a couple of the guys out to the driveway at a family picnic and pointed out that my Honda was the only car in the driveway (out of 11) made in America. They're all hardcore SUPPORT AMERICA, and used to only buy Chevy and Ford.
On the plus side, my aunt just got a Honda minivan. At least I'm getting somewhere with them
Old 08-23-2012, 06:28 AM
purgat0ry's Avatar
Pure ignorance.
Tech: Do some research and get opinions on your guide / sleeve issues.
night
Engine Machining & Assembly
09-20-2018 11:59 AM
redex04
01-31-2007 09:47 PM
99CivicSiBrian
05-31-2006 01:23 PM
newdrifter5
09-07-2004 05:29 PM
Btothe3rdDegree
08-10-2004 09:55 AM
Quick Reply: D16Z6 Valve Guides - What size sleeves/liners do I get?
