New vp c85 any good?
Just wondering if anyone tired the new VP racing c85
http://www.vpracingfuels.com/blogs/v...istent-tuning-
Re: New vp c85 any good?
I'd like to hear what Mr Palo thinks about this fuel running the ID's. I recall a large write up he did about E85 and how it was very corrosive.
Doesn't matter who blends the ethanol, you still have to be aware of things and maintain your fuel system. I'm sure the C85 will work great. If pump E85 works good, any racing blend should at least work that good and have more consistency.
Read this article for the info on maintaining your fuel sytem.
http://www.injectordynamics.com/AlcoholArticle.html
As the link to his article is above to refresh anyone who has not read it or it has been a while since they read it, it was not that e85 or ethanol is corrosive... it is that it attracts water and moisture. Moisture is what does the damage when it is left to sit in a fuel system with bare metal internal components that can rust or corrode.
Talked with my local VP rep today. He deals a pretty substantial volume of VP products in SE georgia and i have been seeing people post MSRP prices of anywhere from 600-750 for 55 gallon drums.
i was given a price of 425.00 a barrel or 50.00 bucks for a 5 gal. pale
i get a pretty good discount with him but i couldn't imagine his walk in pricing being more than 500-525 or so a barrel. we ordered a 5 gal. pale today. going to be doing a back to back test against pump e85 in the next 2-3 weeks. ill post back the results.
Any update
I can get vp fuel easily
And want to get away from the expensive vp import
I'm interested in hearing more from other C-85 users who are running ID injectors. I planned on stepping away from "pump" E-85 this next season thinking that C-85 was the best answer. I know that E-98 is a good choice but I'm just not sure that I have enough fuel system for it, so C-85 would have to be the next choice. I'm sure there are others out there in the same boat.
In for more info guys!
I made 991hp with C85 on 8x 1100 FIC
Iam pretty sure Tony (T1), Rob Morse(TPR) and Speedfactory are running ID injectors
they all run FTW race fuel w/MTBE
MTBE swells ID2000s to around ~1800cc
We have a car running vp import with FIC2150 made 892hp
Location: R.I.P Brian Arbogast...you will be missed, maryland, USA
Is the swelling exactly the same on each injector? I'd be surprised.
If not, what's the point of paying to have a perfectly matched set of injectors, which might end up slightly different after swelling, to an ''undetermined'' flowrate?
Just asking...
Just asking...
i guess that is why their web site says that id2000s are "Incompatible with MTBE"
We switched to the c85 at the last min. All I know is its working fine and the cars running great. Makes plenty of power and still plenty of Injector.. will be changing to mtbe compatible Injectors over the winter.
whats owned..their the same material in the same fuel system under the same conditions why would they not swell the same? lol.... ive run import, q16, c85, thru id 1k's 2k's fic 2150's... the only thing I do is when the car is not run for a while I pickle the fuel system. Run 93 thru the whole system if car is going to sit for a while.... oh and before you ask I have run egt's on all 4 cylinders and they are even.... So it works is it a waste to not get full flow out of a set of injectors .. yes..... there are other options.... runa pair of old school bosh 1600's... and deal with crappy driveability, etc....
I believe the point to dynamically matching injectors is to ensure they all flow the same at small pulsewidths.
If you have 4 injectors having exactly the same response times / dead times, but they all differ slightly in fuel flow after swelling, you kinda lose a part of what was gained by the dynamic flow matching.
This being said, I have no idea if swelling will be exactly the same for each injector after being exposed for a given time, but I doubt ID would assess this.
I believe ID is just smart not to recommend any % of MTBE being used with ID2000s as it might prove difficult to evaluate with precision how the swelling occurs, how it affects actual flowrate vs. exposition time and how it affecta ''set matching''.
