pic request AF civic hb
I just picked up a 87 dx hatch needs some work of course but it'll get there in time. I just want some pics of any clean swapped ones. Thanks ahead of time.
Re: pic request AF civic hb
Any swap info would be greatly appreciated also
i know hasport got mounds and i have to run a em1 rear T bracket what linkage do i run for b18/b20 swapand mines is a dx what kind of wiring do i have to do to get that car running with the swap.
nothing really??
ok I looked up quick info n hasport makes the mount kit. i can use stock b-series axles and em1 rear T-bracket. as far as wiring goes any pointers would be nice and I haven't seen any info on linkage. thanks ahead of time for any help.
that crx is awesome that swap is easier to throw in I'm guessing. how's the aftermarket support for it? or are all your mods custom?
This is a good read by Scott Hairrs
1st Gen CRX legal engine swaps
By Scott Harris, copyright 2002
cbstd@hotmail.com
Current California law states that you may change engines and remain legal. The catch is that the engine going into a car must be from the same model year or newer as the recipient car. And all of the engine's pollution control devises (including the ECU) must be used in the car. As with any car, swapped engine or not, any replacement parts in the ignition, intake, or exhaust must have a CARB tag. Headers and intakes without the CARB tag will create an instant failure at the inspection station. Adjustable cam sprockets are not allowed in California, so I reset my adjustable sprocket to stock settings and replace the plastic timing belt cover when I need to smog-check my car. And your ignition timing must be at factory settings to pass.
JDM engines are cheap and plentiful. But they generally are not clean enough to pass California emission tests. Installing a JDM engine is a risk if you want to pass emission testing.
Now that the legal stuff is out of the way, lets examine what engine/transmission combination can be swapped into the 1984-1987 CRX: Anything engine/transmission that Honda makes will go into the early CRX. End of article.
Oh, what is that you say? What goes in easily? Ah, that is a very different story.
The very first thing to remember about the 1st Generation (1984-1987) CRX is that the USDM engine and transmissions are very different from all subsequent (1988 and later) Hondas. Consequently, if you are changing to a newer motor, you will have to also change to a newer transmission, axles and knuckles that match the new engine.
If money and engineering skill is no object, you could shoe-horn a NSX engine into a CRX. Back in the 80's, somebody stuffed two Accord engines into a CRX. If you do not mind your engine sticking up above the hood, I suppose you could put a tall CRV B series block and transmission into the CRX. But for practical purposes, the B16 engine/transmission is the strongest stock combination that can be made to fit with the hood closed.
Outside of engine size, the most important factor to consider when swapping engines is engine mounts. As I said, the B16 will bolt right to the CRX.. But you will either have to fabricate your own motor mounts or buy an expensive set of motor mounts from www.hasport.com. And you will have to figure out how to adapt the car's wiring harness to the B series engine management system or you will have to source a B series wiring harness. Sport Compact Car did a series of interesting articles in early 2002 about a guy in Arizona who put a B16 into his '87 CRX Si and all the specific details are in those articles.
The cheapest and easiest swap to make into the early CRX is to use the 1986-1989 Integra DOHC D16 engine and transmission. This combination was available in the CRX in Japan and Europe and it is engineered to go right in. Here is a brief overview of these engines.
At the top of the family tree for the D Series, DOHC 1600cc, 16-valve engine is the JDM spec ZC engine of 135 hp. Next in line was the Euro-spec D16A8 which makes about 120 hp. In the US, we got the D16A1 Black Valve Cover version in the 1988-89 Integra, with 118 hp. And at the end of the line is the D16A1 Brown Valve Cover version in the 1986-87 Integra with 113hp. Many people refer to all 1986-89 Integra engines as being a ZC, but this is not technically correct. ZC is Honda's term for the top rated version of its engine. If you can find all of the JDM parts, you could build a USDM D16 into a ZC because all D16 blocks are exactly the same.
The 88-89 Integra engine (black valve cover) is slightly more powerful than the 86-87 models because it has a better intake manifold, domed higher compression pistons, and lighter connecting rods. The 86-87 D16 uses a distributor and ECU that are similar to the stock 1985-1987 CRX Si so
if you use a 88-89 engine, you could either use the 86-87 distributor and ECU (easy) or change over to the later wiring harness and ECU (harder). The transmission gear ratios got changed in the 88-89 model and most performance people prefer the 86-87 gear ratios.
Parts are interchangeable between all versions of the D16 so you could build an engine that uses the best parts of all versions. For motor mounts, you should use the CRX motor mounts for the timing belt side and rear of the engine, at the transmission you must use the Integra transmission mount. Use a complete set of 86-89 Integra axles including the intermediate shaft. and you have to use the 86-89 Integra knuckle/spindle assembly so that you can utilize the Integra 3-piece axles. The 86-89 Integra axles DO NOT plug into 84-87 Civic/CRX knuckle/spindle's. Also, use a complete 86-89 Integra's shift linkage.
If your CRX does not have fuel injection you have two options. You can retro fit your CRX to a pressurized fuel system and wiring harness necessary for fuel injection. Or you can adapt your engine to run on carburetors which will not pass California smog control laws. A twin carb set-up is expensive and difficult to balance. But it will also make more horsepower than a fuel injected car once you get the mixture correct. Theoretically, it is possible to put a D16 head on a stock EW block. I have never seen such a beast and I do not know if there is any material available on making this monster work. Now that you have that bigger engine in, you are home free, right? Well no, because you have to help your suspension deal with an engine that weighs almost 100 pounds more than the stock engine. Thicker torsion bars (I suggest the 23mm size for street cars, 27 or 29mm for race only cars), thicker rear springs and a rear sway bar are all good upgrades. I also highly recommend replacing at least the front lower control arm bushings, the sway bar bushings and end links. And upgrading the stiffness of your engine mounts by filling them with polyurethane glue (let them dry 24 hours before reinstalling them) is a cheap, easy and useful upgrade.
Of course all that extra hp will require extra stopping power. I strongly recommend installing Integra front brakes as a minimum upgrade. The Integra rear disks are cosmetically interesting, but are heavier and not any more effective in daily driving than the stock drums. I have HF aluminum drums on the rear of my '87 Si which are lighter than disks or iron drums, dissipate heat almost as well as disks, and are much cheaper and easier to install than disks. Steel braided brake lines, fresh brake fluid and quality brake pads ( I prefer Porterfield or Hawk) complete the brake upgrades. Avoid installing cheap cross drilled rotors, OEM disks are plenty fine for 99.99% of the driving you will do. If you must get fancy disks, PowerSlot rotors are good. What kind of performance can you expect from this swap? 1/4 mile times, top speed and mileage will vary according to differences in tire compound, transmission type (LSD, gear ratio) and driver skill. Installing an engine with 25% more horsepower than stock should make a significant difference in speed and make a corresponding negative impact impact on mileage. But you knew that already.
So what kind of swap do I have in my car? As I am most interested in Autocross and track racing, I have elected to keep the stock D15A3 engine that came with my '87 CRX Si. 1st Gen CRX's that have been hybrided get classified out competitive classes. Plus, I have increased horsepower in my stock engine and reduced weight in my car to the point that my power to weight ratio is pretty close to a hybrid car's. And the Mugen LSD that I have installed in my transmission makes my power train much more efficient than stock.
The 1st Gen CRX Si's stock D15A3 is an OK engine (very strong bottom end with a so-so head design) that can be built in racing trim to make upwards of 180hp. A street legal D15A3 can be built to make almost 120hp without the weight penalty of the D16.
If you see any errors or omissions in this article please contact me and I will make corrections immediately. cbstd@hotmail.com
cbstd@hotmail.com
Honteggie
08-24-2006 07:43 PM
markpa2
06-20-2004 07:03 PM
