Valet Key/Master Key?
Old 04-14-2012, 03:55 PM
John Anderson's Avatar
Default Valet Key/Master Key?
I have a 97 Honda Civic EX. I bought it about a year ago and I have never been able to use my key to open the trunk or the trunk lock. I did a little research and assumed that I had been given a valet key, seeing as it opens the doors and turns on the car. I went to a local Honda dealer, asked if they could cut a new master key for me, and they told me that 97 Civics didn't come with a master or valet key, and that the previous owner must have changed out the lock on the trunk, and it would cost $150 to re-tumble it. Now I'm no expert, but I don't see why anyone would change out the lock on the trunk. I just wanted to know if 97 Civics came with a valet and master key, so I can try to get a new master key cut, if not, I'll just live with not being able to open the trunk with the key.
Old 04-14-2012, 04:14 PM
motegicivic's Avatar
Default Re: Valet Key/Master Key?
Your dealer must be the stupidest dealer ever. My 96 came with 2 reg keys and a valet.
The key you are using does it have a black plastic head is it round? if so it is a valet.
I would use your vin and have another dealer cut you a master key.
Unless they stopped in 97............that is the question.
Wait........a thought, you know the little lock by the trunk release.....the key you have can you open it or lock it?
Old 04-14-2012, 05:32 PM
No the key I have does not lock or unlock that box by the trunk release.
Old 04-14-2012, 06:38 PM
Cmoya07's Avatar
ok so the 2 keys to the left will be the valet keys and the wider one to the right is the master key that opens your trunk and locks the trunk release go to another honda dealer the one you went to didnt just want to take his time to do it for you
Old 04-14-2012, 06:40 PM
R.I.P. Mark
MRGRIM's Avatar
did you think maybe its been hit in the rear and been replaced
Old 04-14-2012, 06:48 PM
Cmoya07's Avatar
nope my 99 ex coupe came with all 3 keys the dealer didnt want to look it up and cut the key unless the car is a theft recovery and the stole the trunk and it was replaced or damaged like the last post says
Old 04-14-2012, 08:59 PM
My key doesn't look like either of these. It's just all metal. Must be a copy or something like that. I'm pretty sure the car was never in any accidents that would warrant changing out the trunk lock. I think the main problem is that the Honda dealer was an idiot. The bad part is that the only other Honda dealer is a couple hours away. Maybe I can go back to that one and tell them to check again?
Old 04-14-2012, 09:38 PM
Maybe it was an idiot employee that's all. Try someone else, or call honda north america and tell them you need another key made and have them communicate that to the dealer on your behalf.
Old 04-14-2012, 10:33 PM
Cmoya07's Avatar
if the key is all metal than it is a copy for sure.I would do like motegicivic says and call honda
Old 04-15-2012, 06:00 AM
gzes's Avatar
Y don't u call a locksmith? Will be kinda expensive but if the dealer key is not correct either then you will have to call one anyways...
Old 04-15-2012, 06:32 AM
Seagull Management
94EG8's Avatar
Yes they did come with a valet and master key (except hatchbacks)
Go to a Honda dealer and have them cut you a key off the VIN number.
Old 04-15-2012, 06:38 AM
gsrturbo-ek's Avatar
go to a different dealer both my 96 nd 97 came with a master and valet key
Old 04-15-2012, 09:50 AM
deving916's Avatar
when I bought my 00 civic ex, I only had the valet key.
It was thicker then the regular key, so I couldn't open either locks as well.
I went to a lock smith and they just made a thinner copy of the key and it worked fine
Old 06-27-2013, 09:43 PM
HondaNooby24's Avatar
What keys did the Hatchbacks have?
Timothy Yhtomit
02-18-2019 10:07 PM
JStroud52
08-23-2017 06:38 AM
Andrew100
07-23-2017 11:43 PM
Intercooler
11-12-2004 11:04 PM
salvimamasita
10-17-2004 11:51 PM
Quick Reply: Valet Key/Master Key?
